Cisco IOS NAT on a Stick Configuration Example
Hey Rene and Laz,
It seems to work for me in a lab only when the NAT router is also the destination, but when my NAT router is in between the source and the destination then it will reply with its physical interface’s source IP rather than using the loopback’s IP.
Hello Nitay
What you describe is normal behaviour. If you have an arrangement where the NAT router is in between the source and destination, then the physical interface will indeed reply. This is because, in such a situation, you have two hops, whereas, in the lesson, the traceroute response is only a single hop.
What the lesson is asking for is that the loopback IP address respond for the router for traceroute instead of the physical address. The loopback address is on the same router, so it doesn’t count as another hop.
Hey :slight_smile:
Is the policy route-map will overload the CPU?
Every packet to the outside have to go through the policy..
Hello Adi
Policy route maps will indeed use some CPU resources in order to function. Will they overload the CPU? Well, that depends on a lot of things, such as the CPU capacity, the platform being used, the amount of memory available, as well as the expected traffic, and the complexity and number of policy route maps being applied.
For the most part, routers are designed to be able to handle large amounts of data and to process them via route maps. As you design such route maps, just be aware of the possibility of overloading the CPU, so that if it does occur, you can be ready for it and act accordingly.
Ultimately, you’ll have to experiment with the implementation, keeping an eye on the CPU usage. CPU usage will go up well before there is any failure, so you can monitor it and avoid any catastrophic failures well before they occur.
Thanks a lot laz :folded_hands:t2:
Adi
Hello Laz ,
about Scenario 1 : can ip Local Policy only one time be applied on Self-generated Packet ? why this Policy has not been applied for the second Time on The reply Packet that has been sent from L0 Interface " with set Interface L0 command in route Map " ?although the Traffic here has matched the Route Map in ip Local Policy.
Thanks a lot for your Info .
Hello Mohammad
I understand and I share your confusion about this particular implementation. It seems strange to me that PBR would cause a change in the source address of sent packets, but it does. Think about it this way:
Take a look at the diagram once again:
Remember that the local policy will only match locally sourced traffic that matches the ACL.
  • When the original echo request comes in from R1 to R2, it enters Fa0/0. This is not locally sourced, so no PBR takes place.
  • R2 then prepares an ICMP reply. Now that reply is locally sourced, and matches the ACL so PBR is engaged and this packet is sent to the L0 interface.
  • The L0 interface then sends the packet to the destination the original ICMP echo request was sent from, which is 192.168.12.0/24. Note here that PBR would be engaged, but PBR is smart enough to know that it should not send traffic back to the IP address it originated from. So a locally sourced packet with a source IP of 2.2.2.2 will not be sent back to 2.2.2.2 using PBR.
This is a somewhat unusual case because PBR is using a next hop address that is local on the device. This is generally not implemented but is done so here simply to fulfill the requirements of the specific CCIE lab challenge.
Anyone tried this with NAT on a stick with inside range also using dhcp service from the local router? So the ip nat side interface is also gateway for dhcp services supplied by the Cisco router, and ip nat outside to a local loopback (we are trying hide all dhcp clients behind one local loopback, so the upstream device can perform 1 to 1 nat )
Not sure what the best way to explain my current setup, will report back with a diagram when I have time!
Hello Robert
Yes, the setup you described is possible, and it is commonly used. You can have your Cisco router act as both a DHCP server and a NAT device. Here’s a brief explanation:
The router’s interface connected to your local network (LAN) would be the DHCP server, providing IP addresses to all devices on the LAN. This would be your “ip nat inside” interface.
You would then configure NAT on the router, with the same interface acting as the “inside” interface for NAT.
The loopback interface would be your “ip nat outside” interface. You’d configure static NAT rules to map the loopback IP address to the IP addresses of your DHCP clients.
Here’s a basic example of how you might configure this:
interface FastEthernet0/0
 ip nat inside
 ip address 10.0.0.1 255.255.255.0
 ip nat outside
ip nat inside source list 1 interface Loopback0 overload
ip dhcp pool LAN
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
access-list 1 permit 192.168.1.0 0.0.0.255
In this example, the router’s FastEthernet0/0 interface is the DHCP server and the “inside” NAT interface. The Loopback0 interface is the “outside” NAT interface. The “ip nat inside source” command tells the router to perform NAT for any traffic from IP addresses that match access-list 1 (i.e., all IP addresses in the 192.168.1.0/24 range), and to use the Loopback0 interface’s IP address as the “outside” IP address.
This is just a generic example. Please share a network diagram of your particular setup so that we can apply the concept specifically to your situation.
Thank you for the detailed notes, will keep these handy. =)
I also came across a more platform specific item, as I’m working with a 68xx h/w;
A bit more on the design, we are actually running the NAT on a stick inside the same VRF, and there seems to be various support limitations depending on ios or iosxe (we are on ios).
NAT with VRF - IOS vs IOS-XE
Our ios doesn’t support ‘match-in=vrf’ keyword, not sure if its on the features road map, so I
might have to report back to the head designer and ask if we can move the NAT onto a different part of the network (but it will probably still be my problem!).
Thank you for the reply again,
Cheers,
Rob
Hello Robert
Thanks for keeping us up to date on your progress and for sharing the information and resources that you found helpful. This enriches the forum and makes it an even more useful resource for all users.
It can often be difficult when attempting to configure specific features, like NAT on a stick when involving other mechanisms such as VRFs. It’s not always readily perceivable how these mechanisms will interact and behave. And this interaction and behavior may differ from platform to platform, and from software version to software version.
In any case, if you have anything to add as you discover more, feel free to let us know!
Not a problem re: enriching the forum/community. I guess one day I will knuckle down and get up to speed on all the fancy new topics I see popping up as apart of the ever changing CCIE EI blueprint topics!
Cheers, Rob
Thanks again for the lesson. Just one question:
Would scenario one work with the following configuration?
int lo0
ip nat inside
int Fa0/0
ip nat outside
ip nat inside source static 2.2.2.2 192.168.12.2
I don’t think it will work: I was thinking that, since NAT goes before routing on the outside, it indirectly translates the destination of the packet to 2.2.2.2, so then the reply will be initially sourced by 2.2.2.2; but then NAT will translate the source of the reply from 2.2.2.2 to 192.168.12.2 because of the rule, so it will not work.
Is that right or am I wrong or misunderstanding?
Jose
Hello Jose
I tried labbing your scenario up and I have confirmed that the first scenario will not function properly. I found that no NATting takes place at all, because the NAT will only match initial traffic from inside to outside. Here you have traffic originating (incoming) on the outside interface, so routing will take place first, thus it will be routed on R2, will reach the loopback interface, and will be routed again.
The NAT “inside” and “outside” interfaces, the IP addresses used, as well as the direction of traffic must be configured so that the direction of traffic flow is taken into account. For order of operations, take a look at this NetworkLessons note.
Thanks Laz. Here is an interesting scenario of NAT on a stick that I labbed and two possible solutions (apart from subinterfaces as Inside or Outside, or global IP address for destinations) came up.
https://community.cisco.com/t5/routing/issue-with-nat-on-a-stick-using-loopback/td-p/5240310
The LAB issue is due to a misconception of how PBR was “interacting” with NAT. I found out the hard way that:
  • When PBR routes traffic from INSIDE to OUTSIDE (to lo0) then NAT takes place. For returning traffic it happens the same.
However, once traffic is “placed” on the loopback interface on the OUTSIDE, I was expecting NAT to act again from OUTSIDE to INSIDE, but it didn’t happen. This caused the following issue:
Traffic returning from the public destination could not get its destination IP address translated to the USERS one, since again, NAT was only translating from INSIDE to outside (thanks to PBR routing as that) but not from OUTSIDE to INSIDE (which will be what I needed for returning traffic).
EXPECTED TO INTERNET:
EXPECTED FROM INTERNET:
NOTE that NAT_ROUTER has:
and the next hop is also directly connected on NAT router:
Also, CMTS G0/1 is 192.168.1.1.
Cisco somehow expects that behavior, but it didn’t work. Maybe I messed up some ACL, but anyways, the two solutions of the post worked.
Do you know if that is supposed behaviour?
Hello Jose
Wow, that’s an excellent analysis, thanks for sharing that. The scenario involves the interaction of NAT with PBR and is quite intricate, so I don’t know if Cisco deems this behavior normal, however, since your solutions worked, that’s great, and it’s a great resource for others to know as well. Thanks for sharing that!
I am trying to figure out a few things with regard to how NAT on a stick works, and this is what I understand so far:
  1. The source IP address of ICMP response traffic is set to the IP address of the interface the packet with the expired TTL was received on, and the destination IP address of the ICMP response is the source IP of the original packet.
  2. PBR applied to locally generated traffic is forwarded as per set statements, which in this case is the loopback address.
The above makes sense so far, but how is NAT triggered if the traffic never “enters” an inside interface, because I understood it, traffic has to enter/exit inside/outside NAT configured interfaces for NAT to trigger and in this case, even though traffic exits an outside interface, traffic is locally generated, so the criteria is only half met.
Sam
Hello Samir
Your premise is correct. Indeed, for locally generated traffic, there is no “ingress interface” at all because the packet originates in the router’s control plane. So how does it satisfy that inside→outside crossing? The answer is that the Policy-Based Routing (PBR) configuration “manufactures” or simulates the crossing.
But even so, in a NAT-on-a-stick configuration, the loopback interface is marked ip nat outside and the physical interface is marked ip nat inside. Without intervention, a locally generated reply would still just route out the directly-connected physical interface, as per the routing table, which is marked nat inside, so NAT never triggers.
That’s where ip local policy route-map comes in. Unlike a regular interface-level ip policy route-map (which only affects transit traffic), ip local policy intercepts packets that the router itself originates and subjects them to the route-map. The route-map then redirects the self-generated packet to exit via the loopback interface instead.
Now the packet has logically transited from inside to outside satisfying the classic NAT trigger condition. IOS applies the configured ip nat inside source translation before the frame is actually sent out the physical interface.
In other words, the traffic does cross from inside to outside, but that crossing is manufactured by PBR redirecting the outbound path through the loopback interface, and with ip local policy. Does that make sense?
Thanks for responding.
I’ve been doing some more reading and as you said, loopbacks are a special case. So, basically, by using a local PBR and set interface, it is re-injecting the packet into the loopback as though it had ingressed. Is that correct?
Sam
