Your guide did not work for me the some of the commands and methods you used were not available or did not work, i used the following cisco docs link to configure it and it works this way
This is using two 7200 routers in GNS3 running IOS version: 15.2(4)M7
These are the commands i used (enable the gigabit interfaces at the end)
Configuring the PPOE Client:
Set the interface to no IP address:
Client(config)#interface gigabitEthernet 0/0
Client(config-if)#no ip address
Enable the PPPoe global group on the interface, this will create a Virtual access interface for you:
Client(config-if)#pppoe enable group global
*Nov 6 18:33:25.555: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
*Nov 6 18:33:25.567: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Then create a dialer pool, I have called mine number 1:
Client(config-if)#pppoe-client dial-pool-number 1
Now we need to create the dialer interface, then perform the following steps:
• Tie it to dialer pool 1
• Set the encapsulation type to use PPP
• Set the IP address to negotiated so we ask for an IP address from the server
• The set MTU to 1492 as we add 8 bytes to send the frame over ethernet
• Set the authentication type to use CHAP do not forget the callin command
• Set the PPP chap hostname (username need to match what is on the server)
• Set the PPP chap password (needs to match the server)
Config below:
Client(config)#interface dialer 1
Client(config-if)#dialer pool 1
Client(config-if)#encapsulation ppp
Client(config-if)#ip address negotiated
Client(config-if)#mtu 1492
Client(config-if)#ppp authentication chap callin
Client(config-if)#ppp chap hostname TEST
Client(config-if)#ppp chap password TEST
Configuring the PPOE Server:
Configure the username and password on the server to match the username and password the clients will use to authenticate:
Server(config)#username TEST password TEST
Configure the bba-group (broadband access group), I have used the global group in this example, you will see a message that a virtual access interface has been created and the state is changed to up:
Server(config)#bba-group pppoe global
*Nov 6 18:50:43.263: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
*Nov 6 18:50:43.275: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
Tie the bba-group to the virtual access interface:
Server(config-bba-group)#virtual-template 1
Create a Loopback interface and configure the Loopback interface with the IP that you intend to configure your server with:
Server(config)#interface loopback 1
Server(config-if)#ip address 10.1.1.254 255.255.255.0
Configure the interface that the PPPoe requests are going to be coming inbound on, in this case it’s the gigabit ethernet 0/0 interface, set it to use no IP address and also tie the interface to the global PPPoe group:
Server(config)#interface gigabitEthernet 0/0
Server(config-if)#no ip address
Server(config-if)#pppoe enable group global
Server(config-if)#exit
Now we need to tie the virtual access interface to an IP address we can do this by binding it to the Loopback address we created along with configuring the PPP protocol to use chap and setting the MTU to 1492:
Server(config)#interface virtual-template 1
Server(config-if)#ip unnumbered loopback 1
Server(config-if)#mtu 1492
Server(config-if)#peer default ip address pool POOL
Server(config-if)#ppp authentication chap
Then we can configure an IP address pool that we will hand to client, in this case I have allocated .1 through to .20 but you can allocate more If you want:
Server(config)#ip local pool POOL 10.1.1.1 10.1.1.20
Bring both Gigabit interfaces up, the client will now have an IP address on it’s gigabit interface allocated by the server.
