Hello Alan
Thanks for the follow-up, and no worries at all!
Brain farts like that are part of the process, and it happens to everyone who has gone deep into the topics. Itâs great that you worked through that NHRP mapping logic. That clarity youâve gained will definitely pay off as you scale your designs.
Your remaining question about dual-hub, dual-cloud routing is a really good one, and itâs a real-world operational concern. The answer hinges on whether you want to stick with EIGRP or adopt BGP. Here is a brief overview of each option, and the reasoning behind choosing one over the other.
With EIGRP in dual-hub dual-cloud, you must disable split-horizon on the hub tunnel interfaces (no ip split-horizon eigrp 1). This is a DMVPN requirement. However, it opens the door for Hub1âs LAN networks to leak through a spoke and be relearned by Hub2 (or vice versa). The NetworkLessons dual hub lesson shows both hubs sharing a back-end LAN segment where routes exchange directly, and in such a scenario, this is not an issue. But in real deployments where hubs are geographically separated, this becomes problematic.
With two tunnel interfaces per spoke, EIGRP metric engineering (specifically, tuning the delay on the secondary tunnel) becomes fragile and hard to maintain. Routes can end up preferring the longer spoke-via-hub path for hard-to-predict reasons.
Now, for larger and more controlled DMVPN designs, iBGP is often the preferred solution, but it has an issue, too. But this issue is readily solvable. For this reason, iBGP is considered the recommended approach here. Let me give you some more details.
With iBGP, Hub1 and Hub2 peer directly with each other (over a back-end LAN or separate link) and both act as Route Reflectors for their respective spoke groups. When this is done, the problem is that when an RR propagates a prefix to a spoke, it doesnât change the next-hop address. The spoke has no route to the next hop included in the UPDATE message, and it doesnât install the route.
By default, a route reflector does NOT change the next-hop of reflected routes. For this reason, we need to put in the neighbor next-hop-self all command in the BGP configuration of the Hubs so that the reflected routes will also have their next hops changed to those of the RRs, which are the hubs.
This is also beneficial because iBGP provides automatic loop prevention via RR loop-prevention mechanisms using originator IDs and cluster IDs, so you donât need route-map filtering logic to prevent loops.
