Hello can FlexVPN implemented on Cat 9500 and 9300 switches pls ?
Hello Hab
FlexVPN is a feature that is available only on Cisco routers. You can see more info about compatibility and platform support of FlexVPN in the following documentation:
So, unfortunately, the 9500 and 9300 do not support FlexVPN, because these devices are primarily designed for campus and data center switching, rather than being VPN concentrators.
I followed the outline but Iām getting a few errors.
001609: *Jan 6 03:26:24.389: %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Tunnel1 - looped chain attempting to stack
001610: *Jan 6 03:26:26.037: %TUN-5-RECURDOWN: Tunnel1 temporarily disabled due to recursive routing
001611: *Jan 6 03:26:26.037: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, changed state to down
001612: *Jan 6 03:26:26.289: IKEv2:(SA ID = 1):Retransmitting packet
001613: *Jan 6 03:26:26.289: IKEv2:(SA ID = 1):Sending Packet [To 98.xx.xx.xx:4500/From 192.168.1.190:4500/VRF i0:f0]
Initiator SPI : 06D974DD25B1A0DF - Responder SPI : 0FEBD183B05898BB Message id: 2
IKEv2 INFORMATIONAL Exchange REQUEST
Payload contents:
ENCR
001614: *Jan 6 03:26:26.297: IKEv2:Detected an invalid IKE SPI
001615: *Jan 6 03:26:26.297: IKEv2:Couldn't find matching SA
001616: *Jan 6 03:26:26.297: IKEv2:(SA ID = 0):Received Packet [From 98.xx.xx.xx:4500/To 192.168.1.190:4500/VRF i0:f0]
Initiator SPI : ABCEA0BC8F907150 - Responder SPI : 037F1AFB09699BCE Message id: 0
001617: *Jan 6 03:26:26.297: IKEv2:A supplied parameter is incorrect
001618: *Jan 6 03:26:26.297: IKEv2:
001619: *Jan 6 03:26:30.157: IKEv2:Detected an invalid IKE SPI
001620: *Jan 6 03:26:30.157: IKEv2:Couldn't find matching SA
001621: *Jan 6 03:26:30.157: IKEv2:(SA ID = 0):Received Packet [From 98.xx.xx.xx.xx:4500/To 192.168.1.190:4500/VRF i0:f0]
001622: *Jan 6 03:26:30.157: IKEv2:A supplied parameter is incorrect
Hello Matthew
The error messages youāre encountering while configuring FlexVPN on Cisco devices indicate several issues that need to be addressed:
The first one has to do with Recursive Routing Issues. The messages %TUN-5-RECURDOWN: Tunnel1 temporarily disabled due to recursive routing and %ADJ-5-PARENT: Midchain parent maintenance... suggest a recursive routing problem. This typically happens when the route to the tunnel destination is learned through the tunnel itself, causing a loop.
Secondly, it seems that you have IKEv2 Errors. The repeated IKEv2 errors (Detected an invalid IKE SPI, Couldn't find matching SA, A supplied parameter is incorrect) point to issues with the IKEv2 Security Association (SA) negotiation. This could be due to a mismatch in the IKEv2 policy parameters (encryption, hash, authentication, etc.) between the FlexVPN peers.
Without knowing more about your configuration, I can make some suggestions and give you some guidelines as to how you can proceed in your troubleshooting:
Check Routing Configuration: Ensure that the routes to the tunnel endpoints are not learned through the tunnel itself. You might need to define specific static routes or adjust your dynamic routing protocol configuration to prevent recursive routing.
Verify IKEv2 Configuration:
- Check the IKEv2 policies on both ends of the VPN to ensure they match exactly in terms of encryption algorithms, hash algorithms, and other parameters.
- Ensure that the correct keyring and profiles are being used and that the endpoint addresses in the IKEv2 profiles are correctly configured.
- The
IKEv2:A supplied parameter is incorrecterror suggests that there might be a misconfiguration in one of the IKEv2 parameters. Double-check all the parameters carefully.
Review Tunnel Configuration: Verify the tunnel interface settings, including source and destination addresses, and ensure they are correctly configured.
Looking at these configuration parameters you should be able to determine the problem in your topology. Let us know how you get along and if you need any further assistance.
I used this lesson as a model to build my own FexVPN hub and spoke. I did NOT wish to use ikev2 routing and instead plan to use BGP at a future date. so my hub and spoke crypto ikev2 profile has only:
show run | se crypto ikev2 profile
crypto ikev2 profile LNEFLEXVPN_PROFILE
match identity remote address 44.228.114.254 255.255.255.255
match identity remote address 0.0.0.0
authentication remote pre-share
authentication local pre-share
keyring local LNBRwestspoke_KEYRING
aaa authorization group psk list LNE-FLEXVPN default
Currently the tunnel is showing up up on the spoke and I see a āVirtual-Access1ā interface on my hub.
AWSBR02aDC-NEW#show crypto ipsec sa
interface: Virtual-Access1
Crypto map tag: Virtual-Access1-head-0, local addr 10.149.135.44
protected vrf: (none)
local ident (addr/mask/prot/port): (10.149.135.44/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (65.243.77.214/255.255.255.255/47/0)
current_peer 65.243.77.214 port 5761
PERMIT, flags={origin_is_acl,}
#pkts encaps: 5, #pkts encrypt: 5, #pkts digest: 5
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 10.149.135.44, remote crypto endpt.: 65.243.77.214
plaintext mtu 1426, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet2
current outbound spi: 0x487A84DA(1215988954)
PFS (Y/N): N, DH group: none
inbound esp sas:
spi: 0x29F1C09F(703709343)
transform: esp-256-aes esp-sha512-hmac ,
in use settings ={Transport UDP-Encaps, }
conn id: 2001, flow_id: CSR:1, sibling_flags FFFFFFFF80000008, crypto map: Virtual-Access1-head-0, initiator : False
sa timing: remaining key lifetime (k/sec): (4608000/2342)
IV size: 16 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2002, flow_id: CSR:2, sibling_flags FFFFFFFF80000008, crypto map: Virtual-Access1-head-0, initiator : False
sa timing: remaining key lifetime (k/sec): (4607999/2342)
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
and on spoke:
interface: Tunnel150
Crypto map tag: Tunnel150-head-0, local addr 10.44.86.2
local ident (addr/mask/prot/port): (10.44.86.2/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (44.228.114.254/255.255.255.255/47/0)
current_peer 44.228.114.254 port 4500
#pkts encaps: 176, #pkts encrypt: 176, #pkts digest: 176
#pkts decaps: 5, #pkts decrypt: 5, #pkts verify: 5
local crypto endpt.: 10.44.86.2, remote crypto endpt.: 44.228.114.254
plaintext mtu 1426, path mtu 1500, ip mtu 1500, ip mtu idb Port-channel1.801
current outbound spi: 0x29F1C09F(703709343)
inbound esp sas:
conn id: 2020, flow_id: ESG:20, sibling_flags FFFFFFFF80004008, crypto map: Tunnel150-head-0, initiator : True
sa timing: remaining key lifetime (k/sec): (4607999/2307)
IV size: 16 bytes
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2019, flow_id: ESG:19, sibling_flags FFFFFFFF80004008, crypto map: Tunnel150-head-0, initiator : True
sa timing: remaining key lifetime (k/sec): (4607985/2307)
IV size: 16 bytes
outbound ah sas:
outbound pcp sas:
I am unable to ping the hub (172.16.150.1) from the spoke (172.16.150.5).
Any ideas on how I can troubleshoot this issue further?
-Brian
Hello Brian
From the configs you have shared, there donāt seem to be any outstanding issues that immediately point to the problem. The IPsec tunnel itself is successfully established (both inbound and outbound SAs are ACTIVE), so Phase 1 and Phase 2 look fine. The main problem is that there is no end-to-end connectivity to transfer traffic inside the tunnel.
This could be due to several factors. I can share with you some thoughts that may help point you in the right direction for your troubleshooting process:
- Since youāre not using IKEv2 routing, the first thing that comes to mind is that you need to look at your routing configuration. Verify that the hubās routing table includes the spokeās subnet. Spokes should have a default route pointing to the hubās tunnel IP.
- Ensure that the tunnel interfaces are configured correctly and are in the same subnet.
- Verify using
debug cyrpto ikev2 packetanddebug crypto ipsec. See below document for more debugging information:
I hope this gives you some insight into your next steps, let us know how you get along!
Hello, I found a typo in 1.1.1. IKEv2 Keyring.
Dash between pre-shared and key is missing.
Hub1(config)#crypto ikev2 keyring IKEV2_KEYRING
Hub1(config-ikev2-keyring)#peer SPOKE_ROUTERS
Hub1(config-ikev2-keyring-peer)#address 0.0.0.0 0.0.0.0
Hub1(config-ikev2-keyring-peer)#pre-shared key local CISCO
Hub1(config-ikev2-keyring-peer)#pre-shared key remote CISCO
Hello Bernd
Indeed you are correct, thanks for pointing that out! I will let @ReneMolenaar know to make the correction.
Thanks again!
In your reply, you mentioned the overlay and underlay networks. But the 0/0 route seems to be the point of confusion for me on this if I have 3 sites 1 being the hub and the two being the spokes. What happens if I need internet access on any of the sites using a 0/0 route. How does that work when the hub is configuring that on all the sites?
Thank you,
Alan
Sorry, this is a response to one of the first posts on this page:
Hello Alan
If we want to establish internet connectivity at the spokes via the local internet connection, how do we do that? With the current config, the hub pushes a default route to the spokes, so the routing over the overlay network to the internet will go via the hub. Such an arrangement would enable centralized internet access for all spokes via the hub.
The hub uses the IKEv2 authorization policy to āpushā a route to the spokes during tunnel establishment. This is where the hub specifies that the spoke should install a default route via the tunnel. In the lesson, this is done like so:
Hub1(config)#crypto ikev2 authorization policy IKEV2_AUTHORIZATION
Hub1(config-ikev2-author-policy)#route set interface
Hub1(config-ikev2-author-policy)#route set access-list FLEXVPN_ROUTES
Hub1(config)#ip access-list standard FLEXVPN_ROUTES
Hub1(config-std-nacl)#permit any
It is the FLEXVPN_ROUTES ACL that defines what routes will be sent to the hub. Right now, this is everything, and thatās why we see the default route on the spokes. If you want to change that, you can change this ACL to only include the internal routes, and then set up routing at each spoke that will allow internet traffic to exit the local internet connection. This is known as a split tunnel ACL.
Lazarus,
Thank you for the response. I have a lab for different builds for DMVPN and to say the least itās been some work. Trying to do DMVPN over a VRF or tying the source interfaces to a loopback has been challenging. With having a VRF for the overlay DMVPN I could have two default routes in each context since both route tables are different, correct? So global routing table has default to internet for basic routing letās assume to connect to service provider. Then have a VRF for the DMVPN that has its own default route. Am I piecing this together correctly? I guess my main confusion here is that I am understanding your response with the default route over the VRF then all spokes get to the internet over that hub default route. But then what happens with the default route the hub and spokes use to connect to each other for the tunnel endpoints to talk? Hopefully this makes sense.
Thank you,
Alan
Hello Alan
DMVPN can be a challenging technology, especially if you are combining it with other mechanisms as well.
You mention different VRFs. Are you referring to the overlay network routing and the underlay network routing? Or have you introduced VRFs in your topology to fulfil an additional requirement? Because in conventional DMVPN or FlexVPN, you donāt explicitly configure VRFs unless you need them for something else. Iām assuming you mean the overlay and underlay networks.
If that is the case, then we have to look at these differently and not in the context of VRFs. The underlay network for DMVPN is used to allow the Hub and Spokes to reach each otherās physical interfaces. This is a prerequisite in order for them to establish mGRE tunnels between them. This uses conventional routing. Once the mGRE tunnels are created, you then have your overlay network. From the spokeās perspective, the underlay and overlay exist within the same routing table (unless VRFs are explicitly used), but they behave like separate planes, with routing decisions based on the next-hop and exit interface. Any routing in the spoke to the underlay or overlay network will be determined based on the next hop. Any route that uses the tunnel as the exit interface goes on the overlay network, and any route that uses the physical interface goes on the underlay network. If you want to direct some local traffic to exit directly to the Internet, then you must configure routing to exit the physical interface for such traffic.
The confusion may come from the fact that you would like to use a default route for both the underlay traffic (to the internet) and the overlay traffic (via the DMVPN topology). Since you canāt have two default routes in the same RIB without conflict, youāll need to prioritize underlay reachability for tunnel establishment, perhaps using a static host route for the tunnel destination and then using the default route for overlay traffic learned via routing protocols. But this is not an issue of VRFs, it is an issue of employing your routing such that the correct traffic (i.e. the traffic you want) goes over the overlay and the underlay as you desire.
Laz,
First, thank you for the response it is greatly appreciated.
I started a new job where the last engineer was aspiring to get his CCIE and he decided to create DMVPN with the underlay and overlay are in different VRFās. With this being said I am trying to grasp how exactly all this works. The underlay might be in the default routing table, but the DMVPN is certainly in its own VRF. I have been doing all the labs to try and figure this out with front door VRF design. It looks like tunnel source is also using loopbacks. I am sure all this is in good intention, but the config is heavy and complicated to say the least. So, anyone coming in after the fact needs to be very experienced in this design.
Thank you,
Alan
Hello Alan
Ah I see. Labbing it up is the best way to go, because you can learn and test freely without the fear of affecting users. The front door design for DMVPN is a valid approach, and as you suggest, it is indeed well-intentioned. However, as a well-intentioned aspiring CCIE professional, he should have also left at least some documentation to help anyone coming after the fact, like you⦠![]()
But it is an opportunity to learn! Iām not sure how else I can help you other than sharing with you some resources that you may find useful (you may have already come across these in your researchā¦). The truth is there isnāt that much Cisco-published content on the topicā¦
Laz,
thank you for all the help. There is some documentation on the design however, I am not sure how much. I have not got the chance to see it yet.
Thank you,
Alan
Good Day,
Thank you for the lesson, it was helpful. I have Hub and Spoke built using Cisco devices on both ends, but I am straggling with having non-Cisco device as a spoke (Fortigate). VPN is up but the HUB device does not have a route for the Spoke tunnel. It appears that Fortigate is not announcing its tunnel IP during the IKEv2 setup (āroute set interfaceā command in Cisco). Is there any other way to let the HUB know how to reach the Spoke tunnel IP?
Hello Al
This is a common interoperability challenge when mixing Cisco FlexVPN with third-party devices like FortiGate. Although I donāt have hands-on experience in the specific setup you are describing, I can share some possible issues that may cause this problem, which may give you some insight into how to deal with it.
Cisco FlexVPN relies on the IKEv2 INTERNAL_IP4_ADDRESS attribute to dynamically propagate tunnel endpoint routes between peers. The Cisco hub uses the route set interface command in the IKEv2 profile, as you suggested, to inject a static route for the spokeās tunnel IP into the routing table, derived from the spokeās IKEv2 payload. Non-Cisco devices like FortiGate may not send this attribute by default, breaking the routing logic.
Check the FortiGate configuration and ensure that it includes the INTERNAL_IP4_ADDRESS attribute in its IKEv2 configuration. Also, ensure that the FortiGate device has assigned an IP address to its tunnel interface and that it is explicitly advertised to the Cisco hub.
Now, if you find that FortiGate cannot send the necessary attribute, there are some workarounds that you can consider:
- Add a static route for the FortiGate spokeās tunnel network pointing to the hubās interface where the VPN is terminated.
- Configure a routing protocol to advertise routes over the VPN, ensuring that the tunnel interface will advertise the spokeās subnet.
Although not an explicit solution, these thoughts may help you out to troubleshoot further to see if you can resolve the issue. Let us know how you get along!
Thank you for taking time to respond. I will check with Fortinet on the attribute. Could please clarify on the following
ā1. Add a static route for the FortiGate spokeās tunnel network pointing to the hubās interface where the VPN is terminated.ā
I am not able to add a route on the Cisco hub to point to virtual interfaces.
Hello Al
Before I respond, I just wanted to clarify that this is not an ideal workaround. It is somewhat clumsy and will work theoretically. I donāt know the practical implications of doing this, youāll have to see it in practice.
Youāre right, in Cisco IOS you canāt typically add a static route that points directly to a virtual interface like a tunnel unless the tunnel is up and operational. What you can try, and I donāt know how this will behave, is to use the physical interface as the exit interface rather than the tunnel.
This may work because even if your static route points to the physical interface, the Cisco router will still encrypt the traffic if it matches the IPsec policy or SA tied to that interface.
Try it out and let us know how you get along.
In any case, I would suggest you try to resolve the issue by getting the Fortigate to send the INTERNAL_IP4_ADDRESS attribute, which is the ideal scenario.
