How to configure EBGP (External BGP)
i configured bgp on both routers as you did before redistributing bgp routes.
i recevied prefix in sh ip bgp summary
emma#sh ip bgp sum
BGP router identifier 1.1.1.1, local AS number 1
BGP table version is 1, main routing table version 6
0 network entries using 0 bytes of memory
0 path entries using 0 bytes of memory
0/0 BGP path/bestpath attribute entries using 0 bytes of memory
0 BGP AS-PATH entries using 0 bytes of memory
Bitfield cache entries: current 1 (at peak 1) using 32 bytes of memory
BGP using 32 total bytes of memory
BGP activity 0/0 prefixes, 0/0 paths, scan interval 60 secs
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
192.168.12.2    4     2       4       4        1    0    0 00:02:35        4
but i can’t see any prefix in your output.
also can you explain what prefix signifies here.
Thanks a ton for wonderful explanation.
Hi Apurva,
You did receive 4 prefixes. What do you see with the show ip bgp commmand?
I don’t see any configuration for the router IDs.
Is this implicit or just an oversight?
Thanks for your good work!
Rudolf.
Rudolf,
Although it is best practice to do so, explicitly defining the BGP router-id isn’t required. If you don’t define it manually, BGP will take the highest IPv4 address of a loopback, then active interface (in that order).
sv6`89mtq0
I took a break after passing my CCNA. However, iks a good thing I am starting to get at this again as I see a little rust. I currently work in networking and IT but while learning helps that its not the reverse and I am often just working on specific projects not to mention the majority is Brocade (uggglol). Anyway Ia m back and found this post to be easy to understand and hope to get back into the grind again.
19 posts were merged into an existing topic: How to configure EBGP (External BGP)
I seem to be having a problem with some of your labs, specifically where you have to configure a loopback. I keep getting a bad mask /24 when I try to configure loopbacks on my routers. I cannot get this lab to work. My router will not accept 1.1.1.0 /24. I tried the ip subnet-zero command but it doesn’t work either. Any suggestions/ideas?
Hi @williebrown2463,
If you get this message, it means you are entering a network address instead of an IP address.
1.1.1.0/24 is a network address…
  • 1.1.1.0 = network address
  • 1.1.1.1 up to 254 are host addresses
  • 1.1.1.255 = broadcast address
For R1, try using 1.1.1.1/24 :slight_smile:
Hi guys,
one question regarding the MD5 authentication.
If enabled, does this mean that MD5 will hash all TCP packets together with the password configured, then it is send and the other router knowing the same password can recalculate the same hash thus knowing its a legitimate packet?
Florian
Hello Florian,
When you enable MD5 authentication for BGP, each TCP segment is verified with MD5. Both routers know the same password so when they calculate the hash for a segment and it matches with what the other peer sent, we know that it’s a legitimate packet.
For a detailed explanation of what/when is checked exactly, take a look at this RFC:
Hope this helps!
This is my config:
 R3#
    172.16.0.1      4   100      18      17        1    0    0 00:13:R3#51        0
BGP:
R3#sh run | sec bgp
router bgp 100
 no synchronization
 bgp log-neighbor-changes
 network 3.3.2.1
 network 3.3.3.2
 neighbor 172.16.0.1 remote-as 100
 no auto-summary
R1 BGP:
R1#sh run | sec bgp
router bgp 100
 no synchronization
 network 1.1.2.1
 network 1.1.3.1
 neighbor 172.16.0.2 remote-as 100
 neighbor 192.168.0.1 remote-as 200
 no auto-summary
R1 BGP routes:
R1#sh ip bgp summary
BGP router identifier 1.1.3.1, local AS number 100
172.16.0.2      4   100      52      53        1    0    0 00:16:53        0
192.168.0.1     4   200      56      56        1    0    0 00:22:26        0
R1 Routing Table:
 1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       1.1.3.0/24 is directly connected, Loopback1
C       1.1.2.1/32 is directly connected, Loopback0
 172.16.0.0/24 is subnetted, 1 subnets
C       172.16.0.0 is directly connected, FastEthernet0/1
C    192.168.0.0/24 is directly connected, FastEthernet0/0
Hi Rudhra,
What about it? :slight_smile:
If you paste configs/outputs, could you please use the code button? That makes it a lot easier to read :smile:
In practical, when peering EBGP with service provider what would be the proper ACL that apply to the edge router from enterprise user perspective? Could you provide some example on this please?
Hello Arthi
Network edge security is an issue that is much more involved than just the implementation of an ACL at the edge of your network. There is a whole discipline behind securing the network edge. Some links that may help you include:
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Security/SAFE_RG/SAFE_rg/chap6.html
Also, take a look at this response from an expert on Cisco’s Support community about ACLs and other options:
I hope this gives you at least some insight into edge security and gives you a good start to understanding how to secure the network edge.
I have the following topology. I have 2 OSPF area 0, once running in each AS, and the links between the AS routers are set to passive.
To achieve eBGP peerings I have placed static routes onto r1, r2, r3 which has brought the peering up with the add of multi-hop. : ) The question is, on reading online it mentions that in the CCIE lab static routes would not be perferred. Therefore what other options would I have. The only other option I can see is to extend OSPF or should I be using different routing protocols perform route redistrbution.
Hello Rick
In order for BGP peerings to take place, peers must have a routing path to each other. This can be done either via static routing, as you have done, or by implementing a dynamic IGP routing protocol. If there is no functional path between BGP peers, BGP peering will not form.
Static routing is a solution, but because it cannot adjust to changing topologies due to failure or modifications, BGP peering could be lost. The best would be to use a dynamic IGP protocol internally between routers on the same AS.
When you implement an IGP, it should be contained within a single AS. You should not have the same OSPF instance spanning multiple AS’es. For example, you should configure R1, R2, and R3 to be running OSPF between them, and then configure R4 and R5 to run OSPF between them. No redistribution between the AS’es should be configured. All routing that has to take place between the AS’es should be taken care of by eBGP.
Hi Rene and staff
i lab this eBGP topology
There is eBGP session between R1 and PE-3 and between PE-3 end R2 on the same subnet
R1 advertise 172.16.0.0/16 to PE-3
PE-3 advertise 172.16.0.0/16 to R2
R2 dont receive the route 172.16.0.0/16 (10.0.1.0/24 does not belong to this context)
There is no inbound policies in R2 (anyway inbound policies apply between adj-RIB-in and loc-RIB)
I suppose this is because R2 find his own AS (65100) in AS_PATH
How do i solve this issue if i want that R2 knows this prefix ?
I read in a blog that this lab should work and R2 should receive this prefix with next-hop of R1 (and not R3) because eBGP is doing optimization (eBGP sessions are in the same subnet).
In my lab that is not working at all
Hi Rene and staff,
sorry for inconvenience, i found that as-override or allowas-in solved the issue
Hello Dominique
Sorry for not responding sooner, but it’s great that you found the solution and that you shared it with us!
