Hi @ReneMolenaar !
I am confused between the NULL interface and discarding of packet to prevent loops.
Why are packets destined for the summarized network being discarded? The summarized route is the only route installed in tables of routing tables outside this area, no one knows the exact longer prefixes within the summarized route outside the area. If you discard the packet destined for summarized route how will communication work?
Not all packets are being discarded, only the ones where the destination IP (described in a packet) is not contained within the summarised route. The null0 interface is used as a âcatch-allâ mechanism when creating a summarised route. When a route is summarised, the router aggregates multiple specific routes into a single, broader route. The null0 interface is associated with this summarised route to ensure that any traffic destined for a subnet that is not explicitly known in the routing table is discarded, rather than being forwarded, which could potentially create routing loops. HTH Nick
Hello Muhammad
I understand your confusion. It sounds like weâre creating a summary route, and then weâre making all packets that match it be dropped! That sounds counter-intuitive, doesnât it?
Well, let me explain. Letâs take a look once again at the topology in the lesson:
But this time, letâs say that R1 has only three subnets. The fourth one has not been configured.
When we create a summary route in R1 which is the ABR, we advertise the single summary route of 172.16.0.0/22 to R2 rather than three individual routes. That makes OSPF advertisements more efficient. R2 now has an entry in its routing table that looks something like this:
O IA 172.16.0.0/22 [110/2] via 192.168.12.1, 00:03:26, FastEthernet0/0
At the same time, R1 creates a summary route pointing to the null interface, that looks something like this:
O 172.16.0.0/22 [110/2], 00:03:26, Null0
Now, when R1 wants to send a packet to 172.16.1.5, for example, it will match the summary route in its routing table, and be sent to R1.
Now this is the key to the whole situation: When R1 receives that packet, it looks up the destination in the routing table and it matches the specific 172.16.1.0/24 route, not the null summary route! So routing can take place correctly! Remember, routing table matches will always match the more specific prefix, and a /24 is more specific than a /22.
So why is the null route there? Well, what if R2 wanted to send traffic to 172.16.3.3? That network doesnât exist on our R1 router, but it is included in the summary route! So, if such a packet reaches R1, we want it to be explicitly handled. It wouldnât match any more specific routes, but it would match the null route. Since R1 has no route to that destination, it is safest to simply discard the packet.
So you see, a null route will discard only those packets that donât match a more specific route found within the summary. Does that make sense?
Great great great, understood!
Thank you!
Also, any external area packet being sent would always have an exact prefix in the distance, the summary route is only for the routing tables. Any packet destined for the exact summarized subnet is to be dropped, got it.
In which command I can see null0 interface that created when we summarize redistribution of external routes?
Hello Görgen
The Null0 interface is not an actual interface that you can view as you would with a loopback interface of a physical GigabitEthernet interface. You can only see the Null0 entity as part of the routing table.
The only way to see the Null0 interface that is created when you summarize the redistribution of external routes is by using the show ip route command.
The output will show you something like this:
S 192.168.0.0/16 is directly connected, Null0
This indicates that the 192.168.0.0/16 network is summarized and any traffic to a more specific route within this summary that is not in the routing table will be sent to Null0 interface. In other words, they will be discarded.
Hello Team,
In the snippet, I can see that you are stating that there are 4 LSAs for each prefix. Until I saw this statement, I assumed that Type-3 was an LSA for all the individual inter-area prefixes.
So, is each prefix itself an LSA Type-3?
Hello Sathish
First of all, the text should read:
You can see there are 4 LSAs, one for each of the prefixes.
âŠnot 4 LSAs for each of the prefixesâŠ
In any case, the purpose of a Type 3 LSA is to provide a âsummaryâ of all of the routes that are found in a particular area and advertise it to another area. In other words, it advertises inter-area routes.
Yes, ideally, you want Type 3 LSAs to summarize all of the routes within an area as best as possible in order to make routing tables and OSPF messages smaller and more efficient. In this particular case, each prefix in Area 1 is represented separately. You can change this behavior and make the advertising more efficient by using the area range command that is shown immediately after in the lesson.
To answer your specific question, yes, each individual prefix that appears in the OSPF database is considered a separate Type 3 LSA.
Hello Team,
I knew that intra area summarization is not possible. But may I know why its possible? I labbed and witnessed that it was not getting summarized
Hello Sathish
The reason why OSPF will not allow summarization within an area is due to the very nature of the protocol. OSPF is a link state routing protocol, and by definition, every router within the same area must build an identical link-state database (LSDB) for the SPF calculations to take place correctly. If LSAs or routes are filtered within the area, the routers are no longer guaranteed to have an identical LSDB.
Hello Guys.
I want to ask you something silly.. I tested the LSA 5 Summarization, but I used the command area 0 range 172.16.0.0 255.255.255.0
And It worked, at least I can ping every loopback on R1 from R2. The unique difference that I can see in R2 its that routing table show the me the route 172.16.0.0/16 as O*IA instead OE2
Let me share with you my configuration:
R1 Configuration
ip address 172.16.0.1 255.255.255.0
interface Loopback1
ip address 172.16.1.1 255.255.255.0
interface Loopback2
ip address 172.16.2.1 255.255.255.0
interface Loopback3
ip address 172.16.3.1 255.255.255.0
interface GigabitEthernet0/0
ip address 192.168.12.3 255.255.255.0
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 0.0.0.3
area 0 range 172.16.0.0 255.255.0.0
redistribute connected subnets
network 172.16.0.0 0.0.3.255 area 0
network 192.168.12.0 0.0.0.255 area 1
R2 Configuration
ip address 192.168.12.4 255.255.255.0
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 0.0.0.4
(config)#do show ip route
O IA 172.16.0.0/16 [110/2] via 192.168.12.3, 00:17:41, GigabitEthernet0/0
C 192.168.12.0/24 is directly connected, GigabitEthernet0/0
L 192.168.12.4/32 is directly connected, GigabitEthernet0/0
Can anyone please explain me what could happen if I do this?
Hello Daniel
There are a couple of things that Iâd like to comment on. First of all, in your configuration of R1, you have:
in the OSPF configuration section. This means you are including all of the loopback addresses within the summary range. Secondly, on R1 you also have:
You are both redistributing the connected networks and advertising them using the network command. When you do this, the network command takes precedence. So the loopback addresses are being advertised as part of Area 0 and not as external networks.
Now, based on the configurations you shared, you should see something like this in the routing table of R2:
R2#show ip route ospf
O IA 172.16.0.0/16 [110/2] via 192.168.12.1, 00:03:26, FastEthernet0/0
Just like in the lesson.
Now you mention that you also used area 0 range 172.16.0.0 255.255.255.0 (which is different from your shared configuration) and found that the entry in R2âs routing table appears as an OIA route to 172.16.0.0/16. Assuming that the network command was still present, the OIA designation is correct, because this would be considered an Inter-Area route. Does that make sense?
Try tweaking some of the parameters (i.e. change the range subnet to 255.255.255.0) and let us know the results you get so we can help you further in understanding!
A feature could work perfectly without any flaws and then there would be IOS-XR which would still decide to implement the feature slightly differently ![]()
When summarizing routes, XR uses the highest-cost route while XE uses the lowest-cost route for the summary.
This is confirmed by a Cisco document
The summarized route uses the maximum cost of the routes assumed in the range.
However, what I cannot understand is why did they decide to remove the cost option from area x range x.x.x.x. This option ensured that if the lowest-cost route in the summary went down, the summary route wouldnât have to be re-advertised with a new cost, and now itâs gone?
This is a nice exploration of the differences between the XE and XR versions of IOS. Remember, XR is for service providers, and these small yet significant differences are part of the attempt to make these devices operate in a more conservative, reliable, and predictable way.
So why do summarized routes use the maximum rather than the minimum cost of the routes assumed in the range? This approach is a conservative routing strategy designed for service provider networks where accurate metric propagation is critical. Specifically, it:
- Prevents Traffic Attraction Issues: When multiple ABRs advertise the same summary, using the minimum cost can make an ABR appear âartificially closeâ for the entire aggregate, even if many specific destinations within that range are actually much farther away. This can cause persistent suboptimal routing and unpredictable traffic shifts during failures.
- Gives a Worst-Case Guarantee: By advertising the maximum cost, XR ensures that any routing decision made based on that summary metric will satisfy the actual worst-case path cost. The backbone never underestimates the true cost to reach destinations in the summarized range.
These types of behaviors are typically observed on very large networks, such as those of a provider network. Theyâre generally not seen or experienced in branch or enterprise networks.
I wasnât able to find any Cisco documentation that describes this, but I can explain why I think it was removed. Although it is true that without the cost option, if the lowest-cost route in the summary goes down, the summary would need re-advertisement with a new cost. However, this concern applies to the IOS-XE minimum-cost model, not to XRâs maximum-cost model.
The summary metric will NOT change when the lowest-cost component route disappears because the metric changes only if the route that currently defines the maximum cost changes or disappears. So the specific instability youâre worried about (minimum cost disappears â summary metric increases â LSA churn) is avoided by design in XR.
But what if the highest-cost route in the summary were to down? That too would cause a re-advertisement of a new cost, but the cost of the summary route would decrease, making it more attractive, and this is something you donât want to avoid.
The bottom line is that the IOS-XR approach removes the manual cost option to enforce a design philosophy where the control plane must reflect the true topology state. This prioritizes consistency in large-scale SP networks. Hopefully this analysis will give some insight into the design approach of XR compared to XE IOS versionsâŠ
