Thank you for this great explanation.
Make much more sense now ![]()
19 posts were merged into an existing topic: How to create Complex Wildcard Masks
Hi Rene ,
Great article ever ![]()
How i will filter only odd ip from the block 192.168.0.0/24 and allow Even IP from this ??
br//
zaman
The simplest way (which permits only even IPs from 192.168.0.0/24) would be this:
ip access-list standard ACL_PERMIT-EVEN
permit 192.168.0.0 0.0.0.254
Remember that ACLs have an implicit deny all at the end, so nothing other than what is matched would be allowed. If you wanted to let everything through except the odd IPs from 192.168.0.0/24, you would have to tweak this a bit:
ip access-list standard ACL_DENY-ODD
deny 192.168.0.1 0.0.0.254
permit any
–Andrew
When find the wildcard mask for the Even subnet you mentioned:
'The first two octets are the same for all the subnets so we use all zeroes for the wildcard mask. In the third octet we use a 1 (don’t care) for all bits except for the 8th bit…it has to match. ’
Use 1 for all bits except the 8th bit (which is 0) will produce 1111 1110 which gives you a wildcard mask of 0.0.254.255.
Why is it that (except the 8th bit) doesn’t apply to Uneven subnet where the 8th bit is 1? As Uneven subnet also uses wildcard mask of 0.0.254.255,
Hello Kenneth.
Using the same example as that found in the lesson, if you want to specify only the EVEN subnets, then you will use a network address of 192.168.0.0 and a wildcard mask of 0.0.254.255. Note the following:
192.168.0.0 11000000 10101000 00001000 00000000
0.0.254.255 00000000 00000000 11111110 11111111
The last bit of the third octet of the network address must remain 0 since the wildcard mask has a 0 in that position. If that remains 0, then all the values of the third octet will be EVEN, such as 0, 2, 4, 6, 8, 10 and so on.
Alternatively, if you want to specify only the ODD subnets, you will still use the same wildcard mask, BUT, you will use a different subnet address. In this case you would use 192.168.1.0 and a wildard mask of 0.0.254.255. Note the following:
192.168.1.0 11000000 10101000 00001001 00000000
In this case, the last bit of the third octet of the network address must remain 1 since the wildcard mask has a 0 in that position. If that remains 1, then all the values of the third octet will be ODD, such as 1, 3, 5, 7, 9, 11 and so on.
So it is the initial subnet address that indicates whether it is the ODD or EVEN subnets that will be specified and not only the wildcard mask itself.
H Rene,
A question:
With a wildcard mask of 255.255.255.255, does it matter what my source (or destination) addresses is?
For example, is there any resultant difference between any of the three:
deny 192.168.1.0 255.255.255.255
deny 172.16.5.0 255.255.255.255
deny 0.0.0.0 255.255.255.255
Since all the source (or destination) address bits are ignored when looking for a match won’t all addresses be denied?
Perhaps there is some internal difference in the processing of the ACE ?
Michael McK
Hello Michael
All of the following entries within an access list will bring about the same result. (Note this syntax is for a standard access list. Extended access lists require both a source and a destination):
- deny 192.168.1.0 255.255.255.255
- deny 172.16.5.0 255.255.255.255
- deny 0.0.0.0 255.255.255.255
- deny any
Notice the last point is blank. Even if you create an access list and put nothing in it, it has an explicit deny any. Indeed if you go in and configure any of the above (except for the last one) and go look in the configuration file, you’ll see that the device actually translates this into deny any!
So to answer your question, you may use any of the above entries to tell an access list to deny everything. The result is exactly the same.
Thanks Laz,
The most helpful is,
“if you go in and configure any of the above (except for the last one) and go look in the configuration file, you’ll see that the device actually translates this into deny any!”
A mathematical analogy might be that using the quad .255 Wildcard mask with any address results in an “any” as multiplying anything by 0 results in 0.
Michael
