ICND2 Practice Test
(Sam H) #1
Hi NetworkLessons Team,
I’ve run through the ICND 2 practice test, and have found a bunch of errors ranging from incorrect questions to incorrectly marked answers. As an example, one question gives the following config:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet 0/0
router ospf 100
network 10.10.100.60 0.0.0.3 area 0
network 10.10.100.64 0.0.0.3 area 0
network 10.10.100.68 0.0.0.3 area 0
network 10.10.200.0 0.0.0.255 area 0
default-information originate
However the topology image specifies this should be routed over Gi0/1, this makes it really confusing to work out what is asked.
Others I can remember is an IP SLA question that shows the correct answer as being dynamic routing protocols when it is acutally STP config (even says this in the answer explanation). These are definitely worth going over, as in it’s current state I don’t really think it’s a fair test example.
Sam
