for inter-vlan switching. does the switching mode always have to be trunking to the router and not access at all cost. As i believe i have seen somewhere were access was used? Thanks
Kind Regards
Kind Regards
Hi Adil,
This always has to be a trunk otherwise thereâs no way for the router to differentiate to what VLAN the traffic belongs. If you use access mode then you only have one VLAN on the interface.
I have a question?
My network is currently in Production and I need to route VLAnâs without involving my router.
My question is this; I have multiple Layer 3 switches (Nexus 9000 series), if I turn on ip routing, will that disrupt my current traffic in anyway?
Also, if I turn a port into a routed port, will other layer 2 ports on the Nexus 9000 series be able to use that routed port for routing, or is it just between the port connected to the other switch(s)?
Curtis
Hi Curtis,
Your traffic should not be disrupted if you enable IP routing.
Once you turn an interface into a routed port and add an IP address on it then the network will be added to the routing table. It will behave exactly the same as an interface on a router so yes, you can use it for routing.
Keep in mind that your L2 âstuffâ will be gone from the Interface: VLANs, port-security, etc.
Hey Renee,
And what is the difference between âno autostateâ command and switchport autostate exclude
Daniel
Hi Dan,
There are three requirements for the SVI to be up/up:
Hi, I have a situation where my company installed ip cameras in our yard. These cameras are all operating on vlan 10. We also have a wifi network that use vlan 192. In a certain scenario one of the cameras is at a point in our yard where the 192 vlan only exists. So as you can imagine, the there is no communication to this camera because it has an vlan 10 ip but is on the vlan 192 network.. How can i setup routing on the particular switch to allow this camera to communicate back and forth with vlan 10?
Hi Omar,
With two different subnets, this is not going to work. If your switch is configured for interVLAN routing then it will have one IP address on its VLAN 10 interface and another on the VLAN 192 interface. When your camera has the wrong IP address, it will be unable to communicate with the default gateway.
Better make sure your camera gets another IP address when you move it to another subnet.
So since this camera is has an vlan 10 ip address, yet is connected to an interface that is on vlan 192, there is no possible way to get the camera to communicate with the other cameras that are on vlan 10âŚmainly the camera server that has an address of 10.10.11.200?
Thatâs correct. Your camera thinks it can reach your camera server on 10.10.11.200 directly since itâs in the same subnet. It will send an ARP request but there is no device in VLAN 192 that will respond to it.
Normally you can use proxy arp for something like this:
But this is not going to work if you use two different subnets, it only works when for example the camera is in the 10.x.x.x/8 subnet and the camera server is in the 10.1.1.0/24 subnet. In that case, the router/switch can respond with a proxy ARP. It doesnât work for two different subnets.
So I ran into something about secondary addresses on an interface. Could this be a possible solution? Adding a secondary address to an interface and have the camera point to that secondary address as its gateway?
Normally you can configure secondary IP address on the interface yes but this will only work when you are not using that subnet on another interface.
For example, letâs say you have interface VLAN 10 with IP address 192.168.1.1 /24. When you try to add IP address 192.168.1.2 on any other interface then the router/switch will not accept it since you canât use the same subnet on two interfaces.
How come the camera requires a static IP? wouldnât it be easier to use DHCP and a reservation perhaps?
Because the camera is located in distant part of the yard that was designed for our wifi network and is only provided connectivity via that 192 interface.
So if I was to let dhcp assign an ip , it will end up being a 192 address and therefore just wont be able to communicate with other vlan 10 devices, specifically the other cameras.
Ok but why not give it an IP address from the 192.x.x.x range then?
Thatâs no problem. When it gets the correct IP address, it can reach the default gateway and the traffic can be routed to other subnets, including the one where your cameras are.
The default gateway will be your switch (if it supports interVLAN routing) or a router.
So if it gets a 192 address, are you saying that it should be able to communicate with the camera server which is on vlan 10. Explain?
Take a look at the first ârouter on a stick partâ of this lesson:
Itâs the same thing, computerA can reach computerB by using their default gateway.
19 posts were merged into an existing topic: InterVLAN Routing
Ok, will give it an attempt? Get back at you with the results. Thanks greatly appreciated!!!
