Hello Roger
This is an excellent question, and it is an important one to understand the difference between these values stated here. Also, this is a VoIP-related question, an VoIP is really close to my heart, as it is the area of networking I started out with many years ago⌠
The 150ms delay for voice is called a delay budget defined in the ITU-T G.114 recommendation, which is a standards document defining acceptable thresholds for high-quality VoIP. A delay budget is the total end-to-end one-way delay. This budget must cover ALL delay components across the entire path, including:
- Codec encoding/decoding: 5-30 ms (varies by codec)
- Packetization delay: Typically 20 ms (time to fill a voice packet)
- Serialization delay: Time to place bits on the wire for transmission (link-speed dependent)
- Propagation delay: Physical travel time across the medium (~5-10 ms per 1000 km)
- Queuing/buffering delay: Time waiting in queues (what QoS minimizes)
- Jitter buffer delay: Receive-side buffer to smooth arrival times (30-60 ms)
The traffic shaping interval Tc is a parameter that affects only one of these components, specifically, the queuing/buffering delay introduced by the shaping buffer at one particular interface across the whole path.
If you configure Tc = 100ms at one router, packets can be buffered for up to 100 ms at just that single hop. This consumes 67% of your entire 150 ms budget at one hop!
If you are traversing multiple routers, and the Tc is set somewhat high on all of them, you can see how the delay accumulates.
So you see, the component of the delay that the Tc value affects is a small percentage of the total delay budget, but it can quickly add up, especially over many hops.
For a 1 Gbps connection, if you do the math, it turns out that in 2 ms, you can send 2 megabits, or 244KB. Because VoIP packets are typically around 1000 bits, or 125 bytes, you can see that many of them can be transmitted within a single 2ms interval. On the other hand hwoever, voice codecs will packetize voice at intervals of 20ms, so for voice, many of those 2ms intervals will not contain voice packets! On average, youâll get one every 10 2ms intervals. So the âbriefnessâ of the 2ms transmission period is not an issue with VoIP.
