I have a question if PE2 has both routing information on it’s table so why PE1 has only one prefix.
Hello Dinesh
Looking at the lesson, I see that at some point eBGP is configured between PE1 and CE1. Once that is done, we can see that PE1 receives one prefix as shown below:
Now at this point only one prefix is shown because eBGP configuration is not complete for PE2 and CE2. CE2 has already been configured, but not PE2. You can see in the above image that the very next step is to configure PE2. Once this is configured, then PE1 will also see the 5.5.5.5/32 network.
Hi there,
I have an issue with the topology, at this web-site I’ve seen the the topology: https://networklessons.com/mpls/mpls-layer-3-vpn-configuration
But that topology is without redundant line and without RR on the router, and I am struggling with that. Because I would like to do a VPN sie-to-site connection.
Hello Robert
Your topology looks very ambitious! That’s great! Is there something more specific that we can help you with?
Hello Lazaros,
Thank you for compliment, I do not know how but I am trying to do a VPN over the AS1 (as SP), site-to-site (AS2-AS3-AS4-AS5), and I am strugling with several things. VRF MPLS, and now with NAT on site. because I have subinterfaces (Vlans) on each site without gateway for physical interface just default-gateway for each Vlans.
Rob
Hello Robert
I have a feeling that maybe you bit off a little more than you can chew? Looking at such a topology and attempting to implement these concepts can be a daunting task. The most important thing is to first gain a solid understanding of the technologies involved, and then to begin implementing the. I would suggest you go through some of the related lessons first, do the labs there, invest the time to gain the understanding, and then you will be in a position to tackle these bigger problems.
A good starting point is to go over Unit 3 of the MPLS course which focuses on MPLS VPN and VRFs. A good starting point is the following lesson, from which you can continue on with all the lessons in Unit 3.:
You can also take a look at the series of lessons on NAT, starting with the following, and going through the various other involved configurations.
As you go through these, and the tackle your large topology, we’ll be here to respond to your specific questions and queries.
I’m confused between RT and RD..
Can you please help me to understand, whether we can configure different RD values on different PE for same customer or it should be same always ?
And, can we configure export/import RT values for the same customer for two-way communication ?
Just like below :-
PE1# >>>
ip vrf CUSTOMER
rd 1:1
route-target export 1:1 (traffic from PE1 to PE2)
route-target import 1:2
PE2 >>>>
ip vrf CUSTOMER
rd 1:1
route-target export 1:2 (Traffic from PE2 to PE1)
route-target import 1:1
Please help to make me understand …
Mukul Jain
Hello Mukul
The short answer is yes, you can configure different RD values on different PEs for the same customer. Remember that the RD values are used in order to make a particular prefix of a particular customer unique. They are not unique to the customer, they are unique to the prefix. Therefore if you have prefix A on customer 1 off of PE2 and prefix B on customer 1 off of PE1, you can indeed have different RDs. The prefixes at each customer site, along with the RD do indeed remain unique.
I have a successful MPLS-VPN with R1 to R5/R6 communication. R10 is my route reflector. I need to do some additional testing where R1 tags it’s loopback with community 100:100 when sending it to R2. R2 receives the community but it does not get sent to R4.
R1
router bgp 1
bgp log-neighbor-changes
network 1.1.1.1 mask 255.255.255.255
neighbor 10.0.12.2 remote-as 100
neighbor 10.0.12.2 send-community
neighbor 10.0.12.2 route-map set-community out
ip prefix-list set-community seq 5 permit 1.1.1.1/32
route-map set-community permit 10
match ip address prefix-list set-community
set community 0:100 100:100 64984:0 65100:100
R2
r2#show ip bgp vpnv4 vrf CUSTOMER-A 1.1.1.1
BGP routing table entry for 1:1:1.1.1.1/32, version 10
Paths: (1 available, best #1, table CUSTOMER-A)
Advertised to update-groups:
14
Refresh Epoch 1
1
10.0.12.1 (via vrf CUSTOMER-A) from 10.0.12.1 (1.1.1.1)
Origin IGP, metric 0, localpref 100, valid, external, best
Community: 0:100 100:100 64984:0 65100:100
Extended Community: RT:1:1
mpls labels in/out 30/nolabel
rx pathid: 0, tx pathid: 0x0
R4
r4#show ip bgp vpnv4 vrf CUSTOMER-A 1.1.1.1
BGP routing table entry for 1:1:1.1.1.1/32, version 37
6
Refresh Epoch 2
1
2.2.2.2 (metric 3) (via default) from 10.10.10.10 (10.10.10.10)
Origin IGP, metric 0, localpref 100, valid, internal, best
Originator: 2.2.2.2, Cluster list: 10.10.10.10
mpls labels in/out nolabel/30
Hello Jeremy
Nothing out of the ordinary pops out from the configs and the topology you shared. Now you have configured R1 to send the community attribute to its neighbor. Have you made the same configuration to R2 (neighbor ip-address send-community) so that it too will send the community attribute to its neighbor, namely R4? You shouldn’t need a route map in this case since the attribute is already set.
Also, you might want to do some BGP debugging on R2 and R4 to see if the attribute is being sent correctly and if it is being received correctly as well…
The following links may also be helpful:
- Cisco Command Reference
- MPLS VPN Configuration Example lesson where communities are used.
Hopefully this gives you some insight on how to proceed with troubleshooting.
This works now. My original lab that I had issues with was using vIOS for PE. When I switched that to CSRs, everything works great. Thanks for the response!
Please See attachment.
Multiple VRFs configured under the sub-interface for the VLAN-to-VRF mapping on Customer A, and Customer B.
All switches configured with VLANs matching to respective Customer router. For example, VLAN 50 maps to GigabitEthernet0/0/0/2.50.
Desktop default-gateways is the sub-interface (GigabitEthernet0/0/0/2.50) IP address for respective Customer.
The core is complete were PEs established vpnv4, and ipv4 peering between each other. Labels are flowing through the core when trace command was on PE and P routers.
Need assistance with completing the configuration on the PEs. Please see below:
I’m stuck at configuring the PEs where the VLAN/VRFs mappings on the Customer are transported by the PEs into the core.
The PEs and Customer router has a /30 IP address configured between them.
I’ve searched the web for documentation but was unsuccessful in finding anything useful. I have been at this for several weeks, so I decided to reach out to someone for assistance.
I cannot provide specific configuration since I’m reproducing my work environment.
Tim
Hello Timothy
The best suggestion I can give you at this point is to take a look at the following lesson that details the configuration of MPLS Layer 3 VPN including the configuration at the PEs that incorporates VRFs, BGP, as well as the IGP that you may have configured.
In addition to this, there are a whole series of lessons you can see below this one in the Course Contents on the right that further describe configurations specific to the use of other protocols, as seen below:
Take a look and see if those can help you in your troubleshooting process. If you find yourself stuck on something specific, please don’t hesitate to reach out and ask further questions.
My goal is to access Internet (viz google.com/cisco.com e.t.c.) over MPLS VPN Network.
I had a below scenario copied from you.
Final target is to access Internet on AS3 by Windows10 PC on AS1 over MPLS VPN Network.
- I configured eBGP between PE-CE
- Configured ospf as IGP
- Created a VRF “Internet”
- Configured iBGP between PE1-PE2
- Created a static route on CE1 for accessing internet
- Advertised L0 : 5.5.5.5/32 & 192.168.184.0/24 into BGP on CE2 Router
Verification
PE1#sh ip route vrf Internet
Routing Table: Internet
**C 192.168.12.0/24 is directly connected, FastEthernet0/0**
** 5.0.0.0/32 is subnetted, 1 subnets**
**B 5.5.5.5 [200/0] via 4.4.4.4, 00:00:56**
**B 192.168.184.0/24 [200/0] via 4.4.4.4, 00:00:56**
CE1#sh ip bgp
BGP table version is 4, local router ID is 1.1.1.1
r RIB-failure, S Stale
**Network Next Hop Metric LocPrf Weight Path**
***> 5.5.5.5/32 192.168.12.2 0 2 3 i**
**r> 192.168.184.0 192.168.12.2 0 2 3 i**
CE1#sh ip route
** 1.0.0.0/32 is subnetted, 1 subnets**
**C 1.1.1.1 is directly connected, Loopback0**
**B 5.5.5.5 [20/0] via 192.168.12.2, 00:03:20**
**S 192.168.184.0/24 [1/0] via 192.168.12.2**
CE1#
CE1#ping 5.5.5.5 source loopback 0
Sending 5, 100-byte ICMP Echos to 5.5.5.5, timeout is 2 seconds:
Packet sent with a source address of 1.1.1.1
CE1#ping 192.168.184.131 source loopback 0
Sending 5, 100-byte ICMP Echos to 192.168.184.131, timeout is 2 seconds:
CE1#
***CE1#sho running-config***
Building configuration...
Current configuration : 2311 bytes
version 12.4
hostname CE1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
log config
hidekeys
ip tcp synwait-time 5
interface FastEthernet0/0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
interface Serial0/4
no ip address
shutdown
clock rate 2000000
interface Serial0/5
no ip address
shutdown
clock rate 2000000
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Serial2/0
no ip address
shutdown
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Vlan1
no ip address
router bgp 1
no synchronization
no auto-summary
ip forward-protocol nd
ip route 192.168.184.0 255.255.255.0 192.168.12.2
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
CE1#
***PE1#sho running-config***
Current configuration : 2886 bytes
version 12.4
hostname PE1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf Internet
rd 100:100
route-target export 100:100
route-target import 100:100
no ip domain lookup
archive
log config
hidekeys
ip vrf forwarding Internet
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
interface Serial0/4
no ip address
shutdown
clock rate 2000000
interface Serial0/5
no ip address
shutdown
clock rate 2000000
interface Serial2/0
mpls ip
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Vlan1
no ip address
router ospf 1
log-adjacency-changes
router bgp 2
neighbor 4.4.4.4 remote-as 2
address-family ipv4
no neighbor 4.4.4.4 activate
no auto-summary
no synchronization
exit-address-family
address-family vpnv4
neighbor 4.4.4.4 send-community both
exit-address-family
address-family ipv4 vrf Internet
neighbor 192.168.12.1 activate
no synchronization
exit-address-family
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
***P#sho running-config***
Current configuration : 2758 bytes
version 12.4
hostname P
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
log config
hidekeys
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
interface Serial0/4
no ip address
shutdown
clock rate 2000000
interface Serial0/5
no ip address
shutdown
clock rate 2000000
interface Serial2/0
mpls ip
interface Serial2/1
mpls ip
interface Serial2/2
no ip address
interface Serial2/3
no ip address
shutdown
interface Vlan1
no ip address
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
router bgp 2
neighbor 2.2.2.2 remote-as 2
neighbor 2.2.2.2 update-source Loopback0
address-family ipv4
no neighbor 2.2.2.2 activate
no auto-summary
no synchronization
exit-address-family
neighbor 2.2.2.2 send-community both
exit-address-family
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
***PE2#sho running-config***
Current configuration : 2884 bytes
version 12.4
hostname PE2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf Internet
rd 100:100
no ip domain lookup
archive
log config
hidekeys
ip address 4.4.4.4 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
interface Serial0/4
no ip address
shutdown
clock rate 2000000
interface Serial0/5
no ip address
shutdown
clock rate 2000000
interface Serial2/0
no ip address
shutdown
interface Serial2/1
mpls ip
interface Serial2/2
ip address 192.168.45.4 255.255.255.0
interface Serial2/3
no ip address
shutdown
interface Vlan1
no ip address
router ospf 1
network 4.4.4.4 0.0.0.0 area 0
network 192.168.34.0 0.0.0.255 area 0
router bgp 2
address-family ipv4
no auto-summary
no synchronization
exit-address-family
exit-address-family
neighbor 192.168.45.5 remote-as 3
neighbor 192.168.45.5 activate
no synchronization
exit-address-family
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
***CE2#sho running-config***
Current configuration : 2317 bytes
version 12.4
hostname CE2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip name-server 8.8.8.8
archive
log config
hidekeys
ip address dhcp
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
interface Serial0/4
no ip address
shutdown
clock rate 2000000
interface Serial0/5
no ip address
shutdown
clock rate 2000000
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/2
ip address 192.168.45.5 255.255.255.0
interface Serial2/3
no ip address
shutdown
interface Vlan1
no ip address
router bgp 3
no synchronization
network 5.5.5.5 mask 255.255.255.255
network 192.168.184.0
neighbor 192.168.45.4 remote-as 2
no auto-summary
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
Thanks in advance
Manami
Hello Manami
As mentioned in a previous post, it’s difficult to verify or troubleshoot a topology simply by examining the configurations of multiple devices without the benefit of implementing show and other test commands. As mentioned before, it’s a good idea to take it step by step. The steps you created are great, you’ll just have to examine the network after each one to see that all is working as expected.
The following lesson may be helpful in identifying and resolving specific issues found in a network:
If you at least can help me to know if I need any extra setup for Internet to access over MPLS in GNS3 that will also be great help.
Manami
Hello Manami
There’s nothing special that you need to do for an MPLS topology in GNS3 to connect it to the real Internet. You simply follow the same steps that are necessary as described in this previous post:
Hello Laga !
How we can configure to hide label MPLS when we traceroute ?
Example:
When we traceroute: it will show : 2 192.168.23.3 [MPLS: Labels 17/19 Exp 0] 0 msec 0 msec 4 msec
So how to show just only same: 2 192.168.23.3 0 msec 0 msec 4 msec
It’s posible ?
Thank a lot ?
Hello Tung
Traceroute on a Cisco device will always include any MPLS labels that appear within the path. It’s part of the way that Cisco devices operate, and how traceroute is employed on the Cisco IOS. However, if you put a PC on one of the ends of the communication and use tracert from the command prompt, it won’t show the MPLS labels. This is simply due to the way the tracert function is implemented.
Thank you so much Laga !
