I think Packet Tracer doesn’t support “clear ip ospf process”. Bit strange since it’s an important command. You might want to try GNS3 if you want to try this command.
Would like to know that if DR fails then how much time BDR will take to become DR and DR OTHERS to select the BDR among themselves.
And if again our DR becomes active then again it will take the role of DR or it will have to wait for next DR/BDR process selection.
OSPF uses hello packets and a dead interval, when the dead interval timer expires OSPF knows something is wrong and drops the neighbor adjacency. This is when it will switch to the BDR.
The DR/BDR election is “non-preemptive” which means that after selecting a DR / BDR these routers will keep their role. Once the BDR becomes the DR, it will remain the DR.
How come Nancy (192.168.12.1) has become DR for the Donna (192.168.2.2) .?
Donna has got Highest IP for left multi-access segment .
Can you please explain?
Thanks and Regards,
Srini
Hi Srini,
In the example above I increased the priority on Nancy to 200. The priority is checked before the IP address for the DR/BDR election.
I am not using any switches between routers and all my routers are directly connected with FastEthernet like the topology below
R1 – R2 – R3 – R4
R5
I assume the above topology is point-to-point but surprisingly all the routers participating in
DR/BDR election .
Can you please explain ?
show command output for example
R1#show ip ospf nei
10.12.0.2 1 FULL/DR 00:00:38 10.12.0.2 FastEthernet0/0
R2#show ip ospf nei
10.35.0.3 1 FULL/DR 00:00:34 10.23.0.3 FastEthernet0/1
10.12.0.1 1 FULL/BDR 00:00:38 10.12.0.1 FastEthernet0/0
Srini
Hi Srini,
This is because OSPF sees FastEthernet interfaces as “multi-access” and will do a DR/BDR election for these.
If you use “show ip ospf interface Fa0/0” then you’ll see that the default OSPF network type is broadcast.
Srini
cool lesson.
i just noticed, even when the physical interface is administratively down, as long as it has an ip address, it’s still selected as the router id.
int f0/0 = 10.0.0.1 up up
int f0/1 = 192.168.1.1 admin down down
192.168.1.1 is still selected as the router id.
Hmm that’s interesting. On what router did you try? if you do a “clear ip ospf process” does it still use it?
If I do this on a router that’s running 12.4T then it won’t use an IP address of an interface that is down.
im using 7200 ios15. i also tried the clear ip ospf process and rebooting the router. still the same, maybe its bugged.
Hi Ajith,
That’s right, Ethernet interfaces are considered multi-access interfaces. OSPF doesn’t know if you connect your cable to a switch or directly to another router. If you use it as point-to-point then you’ll have to tell OSPF this.
Hi Ajith,
Yes that’s what I mean, when the DR fails and the BDR takes over.
very understandable explanation. It is so helpfull. Many thanks
Ali
Really helpful and easy to follow guides, good job!
Could you please explain the need for using 2 multicast addresses ,224.0.0.5 and 6 for setting up neighbor adjacency and packet exchange in multi-access environments
Ashok
Hope your well. I need clarification to understand. from you example you show below output
Donna#show ip ospf neighbor
192.168.123.1 200 FULL/DR 00:00:30 192.168.123.1 FastEthernet0/0
192.168.123.2 1 FULL/DROTHER 00:00:31 192.168.123.2 FastEthernet0/0
But on my gns3 enviroment i am getting below output for the same. I want to understand on the state of yours
(Full/DROTHER)and mine (Full/BDR). Why has became different? is mine correct or not. Thank You.
DONNA#show ip ospf neighbor
192.168.123.1 200 FULL/DR 00:00:34 192.168.123.1 Ethernet0/0
192.168.123.2 1 FULL/BDR 00:00:35 192.168.123.2 Ethernet0/0
Hi Dani,
The OSPF DR/BDR election is non-preemptive so once a router has been elected as DR/BDR then it will keep this role until you reset OSPF. Because of this, it’s possible that another router got elected as DR or BDR.
Hi Ashok,
On a point-to-point network you know that there’s only one device on the other end. With multi-access networks, there can be 0, 1 or multiple OSPF routers…we don’t know. We could send our traffic as a broadcast so everyone receives it but that’s very inefficient.
Using multicast for this works well, everyone that listens to the multicast address (routers running OSPF) will receive it.
224.0.0.5 is the “all OSPF routers” address and they decided to use 224.0.0.6 to send information to the DR/BDR.
