Hello Shaun.
Yes, you are accurate in your description!
Hello Shaun.
19 posts were merged into an existing topic: OSPF Packets and Neighbor Discovery
I had a question on this forum post. I was curious at what level you learn of this such as CCNP TSHOOT? or if this is not something you pick up any regular cisco training but from trouble shooting experience in real word. I think its great piece of information though especially for multi vendor companies such as mine that might have Brocade and Cisco and the possibility of different MTU`s
andrewď˛Andrew P
Aug '16
ď
Kishor,
I assume you mean the âExStartâ or âExchangeâ state, so I will write about those. If OSPF is having an authentication problem, you will not see the routers stuck in ExStart or Exchange. In fact, you wonât see anything at all. The output for âshow ip ospf neighborsâ will just be blank (if a neighbor relationship hadnât already formed). If a neighbor relationship already formed, and then an authentication problem is introduced, the neighbors will just drop once the dead interval is reached. The reason, in both cases, is because if there is an authentication mismatch, then the other routerâs Hello message will simply be ignored. By ignoring Hello messages, the OSPF state machine will never even begin, let alone get to an ExStart phase.To answer your other question, the most common reason by far for OSPF to be stuck in ExStart is because of an MTU mismatch between neighbors. Besides MTU mismatches, other possibilities include duplicate router IDs, access-list that block unicast packets, or NAT misconfigurations.
I recommend you check out a Cisco article that goes into great detail on OSPF getting stuck. You will find they have a very detailed 14 step explanation as to why an MTU mismatch causes this problem.
2http://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/13684-12.html#exstart2
Hello Brian
@andrew can tell us from his point of view, but Iâd like to share my experience as well. I find that the basic theory necessary to be able to understand these things is given clearly in CCNA and CCNP where we learn about the different states of the OSPF process of convergence. The ExStart and Exchange states are actually first mentioned in CCNA, but are further examined in CCNP. So really, the theory is there from the certifications to be able to comprehend what is going on. The experience allows you to solidify the theory into more a comprehensive and clearer understanding of the concepts. When you face such an issue in the real world and you troubleshoot and figure it out, you fully understand the intricacies of its functionality. Without the experience, these concepts will not be fully understood. But without the theory provided by the certifications, youâll never get a chance to gain the experience in the first place.
very good explanation thanks!
Hi
Are DR , BDR and Master , Slave the same ?
Hi Heng,
These are two separate things.
Dear andrew,
I test this Exstart behaviour by using same router ID on two differnet nodes, i didnt see any of the node goes to Exstart state.
But when changing the MTU on interface it stuck in Exstart state.
//BR
Waqar
Hello Mohammad
Having the same router ID can indeed lead to an OSPF node getting stuck in Exstart state. According to this Cisco Documentation, this can be the case.
In order to duplicate such a scenario however, it may be necessary to have more than two OSPF routers and to have the OSPF processes reset in all routers. It may take some experimentation to get the circumstances right.
Hello laz,
I got your point but my concern here is that when there is MTU mismatch we see in (show ip ospf neighbor) command that neighor is in EXSTART state but with the Router ID scenario we didnt see any of the output depicting that its in EXSTART state although we see the blank output in (show ip ospf neighbor) command when its having same Router ID.
Thanks for the valuable feedback.
//BR
Waqar
Hello Mohammad
I just did a simulation where I had the following topology:
router ospf 1
router-id 1.1.1.1
network 10.10.10.0 0.0.0.255 area 0
network 10.10.101.0 0.0.0.255 area 0
and for R2
router ospf 1
router-id 1.1.1.1
network 10.10.102.0 0.0.0.255 area 0
So the router IDs are the same.
The result that I get from the show ip ospf neighbor command is the following:
Router1#show ip ospf neighbor
1.1.1.1 1 EXSTART/DR 00:00:34 10.10.10.2 GigabitEthernet0/0
and from R2:
Router#show ip ospf neighbor
1.1.1.1 1 EXSTART/DR 00:00:30 10.10.10.1 GigabitEthernet0/0
So I do indeed get the EXSTART state when the router IDs are the same. The reason for this is that during the EXSTART the routers exchange DBD packets. The router and its neighbour form a master slave relationship where the higher router ID becomes the master. If the router IDs are the same, this mechanism of choosing master/slave does not complete and the router gets stuck.
Well explained, let me do the labbing for the same topology.
Thanks alot.
//BR
Waqar
I used the same topology and configuration as you used above but in my case i am not seeing the desired results.
I enabled terminal logging and seeing the below logs:
*Mar 20 10:41:32.276: %OSPF-4-DUP_RTRID_NBR: OSPF detected duplicate router-id 1.1.1.1 from 10.10.10.2 on interface GigabitEthernet0/1
*Mar 20 10:40:31.640: %OSPF-4-DUP_RTRID_NBR: OSPF detected duplicate router-id 1.1.1.1 from 10.10.10.1 on interface GigabitEthernet0/2
and for the (show ip ospf neighbor) i am having Blank Output.
R1#sh ip ospf neighbor
There is the possibility that I am missing something which is stopping me to get the desired results.
R1#show running-config partition router ospf 1
Building configuration...
! Last configuration change at 10:39:04 UTC Tue Mar 20 2018
router ospf 1
router-id 1.1.1.1
R2:
R2#show running-config partition router ospf 1
! Last configuration change at 10:39:07 UTC Tue Mar 20 2018
router ospf 1
router-id 1.1.1.1
I am getting same issue(above mentioned ) in my lab topologyâŚno neighbourship is happening between R1 & R2âŚ
So why we are not getting in our LAB ?
Waiting for your valuable response.
Thanks & Regards,
Arindom
Hello Mohammad and Arindom
This is interesting. It seems that there are two different behaviours that are occurring when the same configuration is implemented between routers. Researching the issue further I have found two Cisco documentations that indicate two different things. First, we are told that if there is no output from the show IP ospf neighbor command, this could be because of identical router IDs between the two routers:
Router IDs are used in order to identify each router in an OSPF network. Routers with the same Router ID will ignore HELLOs sent by each other, which prevents them from forming adjacency. The first line of
show ip ospfcommand output displays the current Router ID of each router.
The above explanation refers to the results you are getting. This is documented here on page 3. Secondly, we are also told that:
MTU mismatch, although the most common, is not the only reason that OSPF neighbors get stuck in the exstart/exchange state. This can also be due to both routers having the same router ID (mis-configuration).
This is the case in my experimentation and is documented here.
This may be due to a platform issue or an IOS version issue. My test was done using two 1941 routers running IOS Version 15.1(4)M4. Can you both @waqar675 and @arindom.nag share your platforms and IOS versions? Weâll get to the bottom of this! ![]()
Nice explanationâŚ
Sorry for late replyâŚtoday morning i tried with your same platform or IOS and getting right output..plz find the detailsâŚ
R1#sh version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 23-Feb-11 14:19 by pt_team
ROM: System Bootstrap, Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
cisco1941 uptime is 5 minutes, 30 seconds
System returned to ROM by power-on
System image file is "flash0:c1900-universalk9-mz.SPA.151-1.M4.bin"
Last reload type: Normal Reload
1.1.1.1 1 EXSTART/BDR 00:00:34 192.168.12.2 GigabitEthernet0/0
R2#sh version
cisco1941 uptime is 5 minutes, 49 seconds
R2#sh ip ospf neighbor
1.1.1.1 1 EXSTART/DR 00:00:38 192.168.12.1 GigabitEthernet0/0
Then i tried with different IOS Version 12.4(25d) for recheck and getting no ouput like as previous(which Mohammad and i got ) please find the detailsâŚ
R4#sh version
Cisco IOS Software, 3700 Software (C3745-ADVIPSERVICESK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 08:18 by prod_rel_team
R4#sh running-config | section ospf
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
R4#debug ip ospf adj
*Mar 1 00:05:38.275: %OSPF-4-DUP_RTRID_NBR: OSPF detected duplicate router-id 1.1.1.1 from 192.168.12.1 on in terface FastEthernet0/0
*Mar 1 00:05:11.367: OSPF: end of Wait on interface FastEthernet0/0
*Mar 1 00:05:11.367: OSPF: DR/BDR election on FastEthernet0/0
*Mar 1 00:05:11.367: OSPF: Elect BDR 1.1.1.1
*Mar 1 00:05:11.367: OSPF: Elect DR 1.1.1.1
*Mar 1 00:05:11.367: OSPF: Elect BDR 0.0.0.0
*Mar 1 00:05:11.367: DR: 1.1.1.1 (Id) BDR: none
*Mar 1 00:05:11.867: OSPF: No full nbrs to build Net Lsa for interface FastEthernet0/0
R4#sh ip ospf neighbor
R3#sh version
R3#sh running-config | section ospf
router ospf 1
router-id 1.1.1.1
R3#
*Mar 1 00:08:02.831: %OSPF-4-DUP_RTRID_NBR: OSPF detected duplicate router-id 1.1.1.1 from 192.168.12.2 on interface FastEthernet0/0
R3#
*Mar 1 00:09:02.839: %OSPF-4-DUP_RTRID_NBR: OSPF detected duplicate router-id 1.1.1.1 from 192.168.12.2 on interface FastEthernet0/0
R3#
*Mar 1 00:10:12.819: %OSPF-4-DUP_RTRID_NBR: OSPF detected duplicate router-id 1.1.1.1 from 192.168.12.2 on interface FastEthernet0/0
R3#
*Mar 1 00:11:12.823: %OSPF-4-DUP_RTRID_NBR: OSPF detected duplicate router-id 1.1.1.1 from 192.168.12.2 on interface FastEthernet0/0
R3#
*Mar 1 00:12:22.831: %OSPF-4-DUP_RTRID_NBR: OSPF detected duplicate router-id 1.1.1.1 from 192.168.12.2 on interface FastEthernet0/0
R3#sh ip ospf neighbor
So Laz final conclusion is which was in my and Mohammad mind( why we didnât reproduce in our LAB & no output was like you ) its happening due to IOS which you mentioned yesterday:smiley:
Aside Mohammad please go through the above mention output and you can try with this âVersion 15.1(4)M4â then you can get which you and i expected.
Thanks & Regards,
Arindom
In the lesson, it states that lsack packets will be transferred upon receiving the dbd packets. However, when dbd packets are sent there is no lsack.
Say for example, the master sends a dbd packet, the slave receives and responds with a dbd packet (might include lsa headers) and the sequence number field is same as the packet that was sent by the master.
Please let me know if my understanding is wrong
Hello Sriguruprassad
This is a good point you bring up. An LSA acknowledgement does not always have to be in the form of an LSAck packet. Acknowledgements can also be implied with the receipt of a link state update. For example, the RFC for OSPF states the following:
Each newly received LSA must be acknowledged. This is usually done by sending Link State Acknowledgment packets. However, acknowledgments can also be accomplished implicitly by sending Link State Update packets.
So to more clearly state it, each DBD packet recieved must be acknowledged. This can be done using a LSAck packet or implicitly using a response such as a LS Update. Multiple LSAcks can also be grouped together and sent in a single LSAck packet as well. More info on this can be found in the RFC link below:
Looking at the cloudshark output you sent, many of the DBD packets sent has been responded to with the LS update sent afterwards as an acknowledgement.
Hello all
I would like to make 2 questions.
Markos
Hello Markos
Concerning question 1, there is no clear cut answer given for the destination IP address for DBDs from DROTHER routers in the RFC2328 describing OSPFv2. It states what kinds of packets use what kind of address (unicast/multicast) except for the DBD. Take a look at Pages 58-59 on the RFC. However, researching further, there seems to be a consensus that the DBD packets are sent to the unicast addresses of the DR and BDR. Now according to the RFC:
On physical point-to-point networks, the IP destination is always set to the address AllSPFRouters. On all other network types (including virtual links), the majority of OSPF packets are sent as unicasts, i.e., sent directly to the other end of the adjacency. In this case, the IP destination is just the Neighbor IP address associated with the other end of the adjacency ⌠The only packets not sent as unicasts are on broadcast networks; on these networks Hello packets are sent to the multicast destination AllSPFRouters, the Designated Router and its Backup send both Link State Update Packets and Link State Acknowledgment Packets to the multicast address AllSPFRouters, while all other routers send both their Link State Update and Link State Acknowledgment Packets to the multicast address AllDRouters.
So it seems the DR and BDR send LSUs and LSAs to the AllSPFRouters multicast address.
For question 2, DBD packets will be sent to a neighbour depending on the neighbourâs state:
Now when receiving DBD packets under various states, routers will either accept them or drop them, depending on the state of the neighbor adjacency. The conditions under which DBDs are sent or recieved are described in detail in the following sections of the RFC:
The RFC link once again:
https://www.ietf.org/rfc/rfc2328.txt
