Rene's ICND2 questionaire question
Hello. Is there a mistake on this question on your test Rene?
---------------------------------------------------0------------------------------------------------------
R1 has been configured with the following OSPF and routing configuration:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet 0/0
router ospf 100
network 10.10.100.60 0.0.0.3 area 0
network 10.10.100.64 0.0.0.3 area 0
network 10.10.100.68 0.0.0.3 area 0
network 10.10.200.0 0.0.0.255 area 0
default-information originate
Assuming that all router interfaces on R1 are correctly configured and are operational, that OSPF has been correctly configured on R2, and that no static routes have been entered on R2, which of the following statements is true about a packet that arrives at R2 and is to be routed?
-----------------------------------------------0------------------------------------------------------------------------------
The answer was:
But for this to be true, shouldnt (the interface that I am showing in red) be called G0/0 rather than G0/1?
Or the static route on R1 be changed to:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet 0/0 be changed
to ip route 0.0.0.0 0.0.0.0 GigabitEthernet 0/1?
Please help, I am confused as to why the answer is that answer.
–Gaby
Hello Martha
Thanks for pointing this out. I have corrected the error and the question should now be correct.
Thanks again!
Thank you lagapides, I was very confused for a while. :slight_smile:
