Routing thru switch
I’m trying to lab up and config edge routing thru a 3560-CX switch and am having some issues.. I’m using a /29 and another /30. The /30 is a P2P, and the /29 is a global subnet for us to use. I’m getting stuck coming back from the edge of the /30, back in…
I ran debug on the router when and it’s sending the back to the right Destination IP, but it’s getting stuck at the 3560-CX..
Router to:
- 12.12.12.2:	Works
- 122.122.122.1:	Fails
3560 To:
- 12.12.12.1:	Works
- 122.122.122.2:	Works
- 12.12.12.1 source IP 122.122.122.1:	Fails
- 122.122.122.2 source IP 12.12.12.2:	Works
ASA To
- 122.122.122.1:	Works
- 12.12.12.2:	Works
- 12.12.12.1:	Fails
Gateway of last resort is 12.12.12.1 to network 0.0.0.0
C       12.12.12.0/30 is directly connected, Vlan13
C       122.122.122.0/29 is directly connected, Vlan133
S*   0.0.0.0/0 [1/0] via 12.12.12.0
site2_switch(config)#do show run | inc ip route
ip route 0.0.0.0 0.0.0.0 12.12.12.1
ip route 0.0.0.0 0.0.0.0 13.13.13.1 250	 ! - This is for backup internet connection
c3560cx-universalk9-mz.152-3.E3/c3560cx-universalk9-mz.152-3.E3.bin
Thanx
Actually in my lab the 3560 switch was replaced with a 3550..
c3550-ipbase-mz.122-44.SE6/c3550-ipbase-mz.122-44.SE6.bin
Never Mind - return route on Router wasn’t configured = router didn’t know where to send the ICMP…
Hello Aaron
Great to hear you resolved the problem, and quite quickly too. Thanks for letting us know of your solution!
We’re here for any other questions you may have!
