The most important thing is to check all protocols that are used on your switch(es) and replace them with non-proprietary ones. For example, PaGP is Cisco’s proprietary etherchannel protocol so you might want to replace that with LACP.
This might also apply for other protocols like VRRP / HSRP etc.
