Taking CCNP SPVI Soon!
I’ll be taking CCNP SPVI 300-515 soon.
I’ve discussed a decent amount of SP-related technologies here with @lagapidis (for which I am very grateful as a some of them didn’t have a relevant lesson).
I’m very confident in 1.0 - VPN Architecture, I don’t think anything there can surprise me. I could configure L3 VPNs (3.0) even if you woke me up at midnight, although I still have yet to cover Multicast VPN.
4.0 IPv6 VPNs was probably the easiest section.
The only section that I am worried about is 2.0 - Layer 2 VPNs. E-LAN, E-line, E-TREE under traditional EoMPLS/VPLS are simple.
What I am most worried about is this section:
2.2 Describe EVPN concepts
  • 2.2.a Data plane and control plane operation
  • 2.2.b Multihoming mechanisms
  • 2.2.c Suppression mechanisms
  • 2.2.d Traffic forwarding operation
  • 2.2.e Traffic engineering (RSVP-TE, SRTE) with IS-IS and OSPF
  1. 2.4 Implementing EVPN
    • 2.4.a EVPN IRB
    • 2.4.b EVPN VPWS
    • 2.4.c EVPN native
For whatever reason, I find EVPN to be difficult. The resources (EVPN over MPLS) are limited and EVPN deployments get very complex, especially if you implement multihoming. I feel like 90% of EVPN’s complexity comes from multihoming and the way the routes are presented.
And it’s not just that, the 5 route types are also a bit difficult to work with. Each one advertises each information, under different circumstances (VPWS vs EVPN LAN, Single-Homed vs Multi-homed, EVPN IRB) and it’s hard to read in the BGP table given how long it is.
@lagapidis From your perspective, have you got any advice regarding SP-level exams and maybe on how to tackle EVPN properly? I’m finishing up with EVPN now but the confidence that I have with other topics isn’t there for this one.
Thank you all for your help, I appreciate you all!
Thank you for the kind words, and for the great discussions you’ve been instigating. To be honest, you are probably more of an expert than I am, as you have gone through this content more recently and more thoroughly than I have. The truth is that we don’t currently have a lesson on EVPN over MPLS or EVPN multihoming because the site wasn’t designed to cover topics in the SPVI exam. I can, however, share with you what I think may be helpful in your preparation.
Concerning the specific blueprint items:
  • EVPN (2.2 and 2.4): Control and data plane operation, multihoming (ESI, DF election, split horizon), suppression (ARP/ND), traffic forwarding, EVPN IRB, EVPN-VPWS, and native EVPN.
  • Troubleshooting (2.1): E-LAN, E-Line, and E-Tree can appear as troubleshooting targets, so be ready to diagnose pseudowire state, LDP sessions, VC ID and MTU mismatches.
  • Ethernet OAM (2.3): This is an “implement” objective, so expect configuration-level questions.
It may also help to map each problem to one mechanism and one route type:
  • Which PEs share an Ethernet Segment, and who forwards BUM traffic? DF election, using Type 4 routes.
  • Split horizon and mass withdrawal: Type 1 per-ES routes.
  • Load balancing to a MAC learned on only one PE: aliasing, using Type 1 per-EVI routes.
  • MAC and MAC/IP reachability: Type 2.
  • BUM tunnels: Type 3.
  • IP prefixes: Type 5 (RFC 9136).
Two things often trip people up.
  1. First, the same Type 1 route looks different depending on whether it’s per-ES or per-EVI. The Ethernet Tag is MAX-ET for per-ES, and the label is an attribute, not part of the route key.
  2. Second, EVPN mobility (section 15 of RFC 7432) is a different problem from multihoming. ESI comparison is what stops a MAC from being falsely flagged as moving between PEs on the same multihomed site.
That’s all for now, I hope it does shed some light and helps you in your preparation. I wish you success, and let us know how it went!
I understand most of the EVPN topics that you’ve mentioned, so I believe that I’ll be fine.
I have some revision up ahead so I’ll cover any inconsistencies (and multicast VPN, since that is my final uncovered topic).
I owe a huge thanks to you and Rene, again. You both helped me with my CCNP Enterprise studies and now with CCNP Service Provider studies, keep up the amazing work.
I’ll post an exam review if I manage to succeed.
Thank you!
