CBWFQ and shaping are often used together for effective bandwidth management. CBWFQ ensures fair bandwidth distribution among different traffic classes while shaping controls the traffic rate to prevent congestion. Shaping can be applied to traffic classes defined by CBWFQ. This means you can classify traffic using CBWFQ and then apply shaping to each class as needed.
Here is an example of a CBWFQ with applied shaping policies. In this example, we’ll assume you have three types of traffic: high-priority (like VoIP), medium-priority (like business-critical applications), and default traffic (everything else). We’ll shape the total outbound traffic and allocate guaranteed bandwidth to each class.
Define Class Maps:
For High-Priority Traffic (e.g., VoIP):
class-map match-any HIGH_PRIORITY
match protocol ip rtp 16384 32767
For Medium-Priority Traffic (e.g., business applications):
class-map match-any MEDIUM_PRIORITY
match access-group 100
Access control list for medium-priority:
ip access-list extended 100
permit ip any any
Create a Policy Map:
This policy map applies CBWFQ:
policy-map CBWFQ_WITH_SHAPING
class HIGH_PRIORITY
priority percent 30
class MEDIUM_PRIORITY
bandwidth percent 50
class class-default
fair-queue
Apply Traffic Shaping:
Assume we want to shape traffic to 10 Mbps. Note we are shaping the traffic that matches the class-default class:
policy-map SHAPING_POLICY
class class-default
shape average 10000000
service-policy CBWFQ_WITH_SHAPING
Class Maps: Define the types of traffic. HIGH_PRIORITY for VoIP (using RTP ports) and MEDIUM_PRIORITY based on an ACL.
Policy Map for CBWFQ: CBWFQ_WITH_SHAPING allocates 30% of bandwidth to high-priority traffic, 50% to medium-priority, and the rest is handled by the default class using fair queuing.
Traffic Shaping: SHAPING_POLICY shapes the traffic that does not match the high or medium priority classes to a rate of 10 Mbps. It references CBWFQ_WITH_SHAPING to apply CBWFQ within this shaped traffic.
Interface Application: The final policy SHAPING_POLICY is applied to the outbound direction of the interface GigabitEthernet0/0.
This configuration is a basic example and might need adjustments based on the specific network setup, traffic patterns, and requirements. You can also apply shaping only to the high- and/or medium-priority traffic, or to all the traffic. This is just a basic example that I hope will help you understand how CBWFQ and shaping can be applied together.
Hi Rene and Laz,
First of all thank you so much for such a great lesson.
I follow your guide to build a topology for shaping configuration. I use EVE NG with vIOS router, vIOS switch and vPC images, but my vPC does not support iperf. Can you please give me the information of the image you used for hosts?
So I connected my computer to port 31, and port 2/1 is uplink. The device is a 4500X. Now what happens when I don’t write the 2nd sequence in ACL and I don’t apply policy-map to port 1\31… So I make the speed of traffic from 10.70.0.0/16 to any 10 MB with shape. Then I write it as output to port 2/1. So far so good. However, when I do a speed test, I only see a change in my upload traffic. So, my upload traffic has decreased from 150 MB to 10 MB. But my download traffic remains like a bonfire. Now I insert the 2nd sequence into the ACL. That is “10.70.0.0 0.0.255.255”… Then I apply it to port 31. I wanted to do something like this to figure out why it didn’t work in the previous process. My goal is to shape traffic from the internet to my host. This time, I saw that my download traffic was 10 MB after measuring it with a speed test. Can you explain to me why this is so?
The initial access list you mentioned (without the second statement) is:
ip access-list extended ShapeTest
permit ip 10.70.0.0 0.0.255.255 any
And this is applied outbound as a service-policy on both TE1/31 and TE2/1, correct?
When traffic is sent from our host to the Internet, the outbound service policy on TE2/1 will kick in, because the traffic has a source of 10.70.X.Y which is the IP address of your PC, and it is within the address space specified by the ACL. So outbound or upload traffic will be shaped to 10 Mbps.
When traffic goes from the Internet to our host, it is the outbound servie policy on TE1/31 that kicks in. No traffic matches this ACL! So no shaping takes place.
When you add the second line to the ACL, then the service policy on TE1/31 does match traffic using that second entry, and thus you see the correct shaping. Does that make sense?
I have a few questions regarding this configuration.
Is there generally any reason to set the BC value yourself? Because if you do so, not only will you tell the device to ignore its own way of calculating the BC but you might also end up with unexpected results if you don’t understand shaping.
And generally, when it comes to shaping, if our ISP is policing our traffic, we would most likely create an ACL that would match everything and then shape the traffic.
Just wondering, if our ISP allows us to burst to a certain rate, does our contract with them include this type of information? How many bytes can we burst into after a certain period of inactivity?
If shapers queue traffic, shouldn’t we also apply some queuing mechanisms such as CBWFQ and LLQ?
The final thing is that I only thought that shaping would buffer/queue traffic if the data rate exceeded the CIR. But this isn’t quite true, right? Shaping always buffers traffic because you’re always sending data and then suddenly stopping per TC.
Setting the Bc value yourself is not typically necessary and is usually best left to the device to calculate automatically. As you mentioned, manually setting it can lead to unexpected results if not done correctly. Only under very specific conditions and only after extensive experimentation should you change that value.
When it comes to shaping, if your ISP is policing your traffic, you would typically create an ACL that matches all traffic and then shape accordingly. This is to ensure that your traffic does not exceed the rate at which your ISP is policing, which would result in dropped packets.
If your ISP allows you to burst to a certain rate, this information is typically explicitly defined and described within the contract. Based on that information, you should be able to appropriately configure your shaping so that you don’t get any packets dropped.
Shapers do indeed queue traffic, and it can be beneficial to apply queuing mechanisms such as CBWFQ and LLQ. These mechanisms can help manage the traffic in the queue and ensure that high-priority traffic is sent first. This is especially important for time-sensitive traffic such as VoIP, where the delays introduced by shaping can be devastating to such applications.
The purpose of shaping is to smooth out bursts and ensure a consistent flow of data. As such, shaping may also queue data when the CIR is not necessarily exceeded.
