Hello Andrew
Let me walk through it myself as well, I think it will be easier to explain:
- H1 pings H2
- Because H2 is in a different subnet, H1 sends the packet to the default gateway, that is, SVI VLAN 10 on SW1.
- SW1 decapsulates the frame and looks at the IP header. Destination IP address is that of H1. If it has the ARP entry, then it knows the destination MAC address to place in the frame header, and it does so.
- If it has no entry for the destination MAC in the MAC table, then it will be flooded out of all ports on VLAN 20 and all trunks that include VLAN 20, so H3 does indeed receive it too).
- SW2 will receive the packet. If the MAC address of H2 is in the MAC address table, then it will be forwarded only out of Fa0/2. Otherwise it will be flooded to all VLAN 20 ports.
- H2 receives the ping, and responds to the IP address of H1. It sends the response to the SVI VLAN 20 of SW2.
- It decapsulates the frame, checks the destination IP, and uses the ARP cache to find the destination MAC, and populates the frame header with destination MAC.
- If it doesn’t have an entry in the MAC address table for this destination MAC, it will be sent out all of the VLAN 10 access interfaces and trunks that include VLAN 10, reaching SW1.
- if the destination MAC is in the MAC table, the frame is forwarded out of Fa0/1 to go to H1. If it is not in the MAC table, it is flooded out of all VLAN 10 access ports and trunk ports that include VLAN 10.
Sorry for restating this, but it helps in verification. Your understanding is indeed correct. SW1 will never learn H2’s MAC address because all traffic between H1 and H2 is routed at SW2, so H1’s MAC address never reaches SW1 for it to be recorded.
