The 9000v images are one of the few that you can download without a contract.
https://software.cisco.com/download/home/286312239/type/282088129/release/10.4(5)?i=!pp
For L3 VNI or L2 VNI, if a host in VLAN 10 needs to connect to an external network or a host in a different location, such as a branch, what would the topology and traffic flow look like?
Should we create an interface VLAN on each switch and enable OSPF?
How would the Leafs communicate with the border leaf or spine in this case?
Hello Diyaa
If a host on VLAN 10 needs to connect to an external network or a host in a different location, you would simply have to route traffic to the subnet that you want to route traffic to. In the example in the lesson, S1 in VLAN 10 is trying to reach a subnet external to its own, (i.e. VLAN 20 where S2 is). The traffic flow would look the same as what is in the lesson, but instead of VLAN 20, you would have what is known as a border leaf switch. This is a VXLAN switch that acts as a gateway between the VXLAN overlay and external networks. The logic is the same as in the lesson, but instead of S2, you would have some network device that connects to a network outside of the VXLAN domain. Does that make sense?
Thanks for your reply.
Just to clarify, letâs say Leaf-1 acts as a Border Leaf switch and has a link to Router-A. Router-A has a default route, and we need to redistribute this route to Leaf-1 and Leaf-2.
Should Router-A be part of VRF CUSTOMER, or does it have to be part of the default VRF?
Hello Diyaa
Yes, exactly, thatâs the idea. You must somehow advertise that route into the fabric so you can reach destinations outside of your network.
That depends upon the intended scope of the default route and the design requirements. If the default route is only for the specific tenant that is served by that VRF, then it can be in the same VRF. However, if its purpose is to provide connectivity to multiple VRFs, then it would be preferable to put it in the global routing table (which is the default VRF).
Can you please explain the packet flow of inter-vlan / inter-subnet host communication in flood and learn mechanism?
Hello Rahul
Letâs start off with a high level overview of âinter-subnetâ communication in a flood-and-learnâbased VXLAN environment. Although modern VXLAN deployments typically use MP-BGP EVPN for more efficient control-plane learning, understanding the original âflood and learnâ approach helps clarify the core forwarding concepts.
Inter-subnet routing in VXLAN involves two big steps:
Letâs dig deeper and take a look at some more detailed steps of this process:
Letâs assume we have two hosts, Host A (IP in VLAN 10) and Host B (IP in VLAN 20). VLAN 10 and VLAN 20 each map to different VXLAN Layer 2 VNIs, and there is typically one L3 VNI (VRF) for routing.
ARP Resolution (Initial Steps)
Routing at the Source VTEP
Traversal in the Underlay
Decapsulation and Delivery at the Remote VTEP
The VTEP that owns VLAN 20 for Host B receives the encapsulated packet, decapsulates it, and performs the routing/forwarding decision for VLAN 20 locally. It sees that Host Bâs MAC/IP is local, does an ARP or MAC lookup, and forwards the packet out of VLAN 20.
Host B receives the traffic.
Response Traffic from Host B to Host A
âThis however requires that you have set up BGP EVPN.â
As we have already configured BGP EVPN in this lesson surely just adding ingress-replication protocol bgp and removing the multicast config mcast-group 239.1.1.1 would fix this alone?
Just making sure iâve got this correct
Cheers
Rich
Hello Rjbotham
You are correct, simply taking the steps you suggest would resolve the issue. My statement before comes as part of a longer thread and conversation with Aqueel that starts here. Because the conversation was being steered away from the scenario in the lesson, I was just confirming that BGP EVPN is still required for what was geing discussed. If you read the whole thread, youâll get the gist of it.
In the Final configs it included the mcast group 239.1.1.1 on the nve interfaces of the leafs but i dont think it was mentioned in the video. My NVE peers wouldnt come up without this in my lab. Feature PIM was left disabled in this lesson and my lab. Why did I need to add the mcast group to the NVE, in additon not enable pim?
Hello Rafa
Good catch! Thatâs an important part of this particular configuration. Strictly speaking, as stated in the lesson:
Technically, we donât need multicast in the underlay network because weâll only have inter-VNI traffic. We donât have intra-VNI traffic between hosts within an L2 VNI. Because of this, I didnât configure PIM on the switches.
So Rene followed this approach in the lesson. Indeed, the multicast commands in the lesson and in the final configs under the NVE interfaces were unnecessary. Now Rene went over this lesson again with me, and it turns out that the video configuration is correct and it works. You can get the required configs here:
Now I donât know why in your particular situation the configuration didnât work until you put in those commands. You need something to deal with BUM traffic. In the video, Rene included the host-reachability command under the NVE, so that may have resolved the issue. You may not have had that, and the multicast command resolved it. In any case, all of this info gives you more direction in your troubleshooting process. Let us know how you get along!
Hello.
Thanks for the lesson.
I wanted to ask something from my ignorance about the limitations of MP-BGPâŚwhy is not possible to advertise via MP-BGP an IP-MAC mapping ? I was thinking that if possible, it will eliminate the need of having to configure mulitcast flood and learn for unknown unicast traffic by having the leaf swicthes replying to ARP Requests as a proxy. ARP Suppresion still has the inconvinient that when a downstream host at the very first time sends an ARP Request for a remote host in the same VNI then we still need multicast to make the ARP request get to the remote VTEP. Why not learning both IP and MAC via MP-BGP and just have Multicast on the underlay for broadcasts and multicasts?
Jose
Hello Jose
Actually, MP-BGP EVPN does exactly what youâre asking for. It advertises IP-MAC mappings, and this is one of the fundamental features that makes EVPN so powerful. EVPN Type 2 routes are specifically designed to carry both MAC addresses AND their associated IP addresses in BGP updates.
However, you correctly noted that âat the very first time⌠we still need multicast.â This is not because of a limitation of MP-BGP EVPN, but it is a characteristic of what is known as the âsilent host problemâ.
If Host A connects to the network but remains completely silent (sends no traffic, no GARP), the local VTEP has no way of learning it. Since the VTEP doesnât know Host A exists, it cannot advertise a Type 2 route. So when Host B tries to ARP for Host A, Leaf B checks its BGP table but finds no entry. So then Leaf B must flood that ARP request (via multicast or ingress replication) to discover the silent host.
Once Host A replies, the local VTEP learns it, advertises the Type 2 route, and all subsequent ARPs are suppressed.
But the silent host problem is not the only reason to provision for BUM traffic. You must still provision for true broadcast traffic used by protocols such as DHCP, and some NetBIOS traffic, as well as for true multicast traffic, including streaming protocols, and some routing protocols.
Now you can eliminate underlay multicast entirely by using ingress replication (head-end replication), where the ingress VTEP unicasts copies to all remote VTEPs. The replication list is built automatically via EVPN Type 3 (Inclusive Multicast Ethernet Tag) routes, but it is not very scalable, and should be used only for a limited number of implementations.
So ultimately, the limitation is not in MP-BGP or EVPN, they already carry IP-MAC mappings. The limitation is that you can only advertise endpoints that have been learned; if a host is completely silent, thereâs no authoritative source to originate its mapping until someone tries to discover it.
Thanks Laz. You are right and made me understand now⌠âThe limitation is that you can only advertise endpoints that have been learned; if a host is completely silent, thereâs no authoritative source to originate its mapping until someone tries to discover it.â
I think I did not express my question right the first time, sorry. I had the doubt on this lesson because Rene creates and advertises on the VRF Address Family the downstream networks (on LEAF switches). Why? I get that it is needed to work, but why is the Type-2 route not âenoughâ for the LEAF to be able to use such route for both L2 forwarding and L3 routing (this is, use the same route for the MAC lookup or for the IP lookup). Why do we need to have different route types for each purpose within MP-BGP?
Hello Jose
I understand, I apologize for not focusing on your core question the first time. Thanks for the clarification!
Type-2 routes alone are insufficient for both L2 and L3 forwarding, even though they contain IP information. While Type-2 routes do carry IP addresses, they serve a fundamentally different purpose than Type-5 routes. Hereâs why both are needed:
Type-2 routes can be thought of as host announcements. They say âI have this specific MAC address and this specific IP (/32 or /128) at my VTEP.â Theyâre designed for
The key limitation that doesnât allow them to be used more broadly is that Type-2 routes are reactive. They only exist when a host has been learned through ARP/ND or data plane traffic. This creates the âsilent hostâ problem you already understand.
On the other hand, Type-5 Routes can be thought of as IP prefix advertisements, or subnet announcements. They say âI can route to this entire prefix (like 10.10.10.0/24) via my VTEP using the L3 VNI.â They are designed for:
Type-2 alone isnât enough due to several reasons. First of all, the silent host problem which youâve already understood. If a host at 10.10.10.50 has never spoken, thereâs no Type-2 route for it. Without a Type-5 route, there is no control-plane-authoritative way for a remote LEAF to select the correct VTEP for first-hop routing. The Type-5 route provides subnet-level reachability, allowing traffic to be steered to the correct VTEP, where local ARP resolution occurs.
Secondly, thereâs scalability. Imagine 10,000 hosts in your fabric. Using only Type-2 routes means 10,000 individual /32 host routes flooding your BGP tables and consuming hardware memory space. Type-5 routes let you advertise a single /24 summary instead of thousands of /32 entries.
Thirdly, remember that Type-2 routes use Route Targets tied to the EVI/L2VNI (per-VLAN), while Type-5 routes use Route Targets tied to the VRF/L3VNI. This separation gives you fine-grained control over L2 vs L3 reachability.
When Rene configures the VRF address-family to advertise those downstream networks, heâs creating Type-5 routes that provide subnet-level reachability independent of host learning. Make sense?
Thanks a lot Laz! Appreciate your help!
