I’m looking into various design considerations to build out active-active data center. Some of these are:
Low latency load balancing and sync of databases.
Geo-enabled load balancing.
Replication aware monitoring.
Localized E-W traffic using distributed default gateway. - This is first time I heard about this one. Does anyone know how it works and how to implement?
I’m sure there are lot of things to take into account and I’m only getting started. If anyone knows of a design document I’ll appreciate that.
The concepts you are listing here are quite broad and include many different technologies and architectures. Such topics are not typically covered within the core content of the fundamental CCNA/CCNP/CCIE curriculum, and are thus not covered in any depth on the site.
However, doing some Internet searching myself, I’ve come up with the following links that may give you a good start on some what you list above:
