I have to replace four ASA 5550s running version 8.2.5 with four 555Xs running version 9.1.X. I tried to convert the configuration from 8.2.5 to the latest by stepping through the recommended upgrade process. I have a test 5550 and I put the production configuration on it after I down graded the device to 8.2.5. I was going to change the boot option to boot into 8.4.3, but when I did that the firewall hit a snag with the conversion and went into an endless loop. Since I captured the reboot process I saw the message that in the outside ACL one of the objects were too long, 15 characters. Does anyone know if there is a limit on the object names?
