I am having issue sending traffic from the ASA LAN but can pink the LAN of the Meraki from the ASA using the inside interface and help.
running config
Result of the command: “SHow run”
: Saved
ASA Version 9.8(2)
hostname ciscoasa
names
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address dhcp setroute
interface GigabitEthernet1/2
bridge-group 1
nameif inside_1
security-level 100
interface GigabitEthernet1/3
bridge-group 1
nameif inside_2
security-level 100
interface GigabitEthernet1/4
bridge-group 1
nameif inside_3
security-level 100
interface GigabitEthernet1/5
bridge-group 1
nameif inside_4
security-level 100
interface GigabitEthernet1/6
bridge-group 1
nameif inside_5
security-level 100
interface GigabitEthernet1/7
bridge-group 1
nameif inside_6
security-level 100
interface GigabitEthernet1/8
bridge-group 1
nameif inside_7
security-level 100
interface Management1/1
management-only
no nameif
no security-level
no ip address
interface BVI1
nameif inside
security-level 100
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any1
subnet 0.0.0.0 0.0.0.0
object network obj_any2
object network obj_any3
object network obj_any4
object network obj_any5
object network obj_any6
object network obj_any7
object network INet
subnet 192.168.2.0 255.255.255.0
object network NETWORK_OBJ_192.168.0.0_24
subnet 192.168.0.0 255.255.255.0
object network NETWORK_OBJ_192.168.2.0_24
access-list outside_cryptomap_2 extended permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit ip any any
access-list outside_cryptomap_1 extended permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list outside_cryptomap extended permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list outside_cryptomap_3 extended permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside_1 1500
mtu inside_2 1500
mtu inside_3 1500
mtu inside_4 1500
mtu inside_5 1500
mtu inside_6 1500
mtu inside_7 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (inside_1,outside) dynamic interface
nat (inside_2,outside) dynamic interface
nat (inside_3,outside) dynamic interface
nat (inside_4,outside) dynamic interface
nat (inside_5,outside) dynamic interface
nat (inside_6,outside) dynamic interface
nat (inside_7,outside) dynamic interface
object network INet
nat (any,outside) dynamic interface
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 255.255.255.255 32.208.56.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
http server enable
http 192.168.2.0 255.255.255.0 inside_1
http 192.168.2.0 255.255.255.0 inside_2
http 192.168.2.0 255.255.255.0 inside_3
http 192.168.2.0 255.255.255.0 inside_4
http 192.168.2.0 255.255.255.0 inside_5
http 192.168.2.0 255.255.255.0 inside_6
http 192.168.2.0 255.255.255.0 inside_7
http 192.168.1.0 255.255.255.0 inside_2
http 192.168.1.0 255.255.255.0 inside_3
http 192.168.1.0 255.255.255.0 inside_4
http 192.168.1.0 255.255.255.0 inside_5
http 192.168.1.0 255.255.255.0 inside_6
http 192.168.1.0 255.255.255.0 inside_7
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto ipsec security-association pmtu-aging infinite
crypto map outside_map0 1 match address outside_cryptomap_2
crypto map outside_map0 1 set peer 88.77.231.38
crypto map outside_map0 1 set ikev1 transform-set ESP-AES-256-SHA
crypto map outside_map0 1 set ikev2 ipsec-proposal AES256
crypto map outside_map 1 match address outside_cryptomap_3
crypto map outside_map 1 set peer 88.77.231.38
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
crypto map outside_map 2 match address outside_cryptomap_1
crypto map outside_map 2 set peer 88.77.231.38
crypto map outside_map 2 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 2 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map 3 match address outside_cryptomap
crypto map outside_map 3 set peer 88.77.231.38
crypto map outside_map 3 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 3 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
crypto map outside_map interface outside
crypto ca trustpool policy
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 28000
crypto ikev2 enable outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 28800
telnet timeout 5
ssh stricthostkeycheck
ssh 192.168.2.0 255.255.255.0 inside_1
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
dhcpd auto_config outside
dhcpd address 192.168.2.100-192.168.2.254 inside
dhcpd dns 192.168.2.51 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy GroupPolicy_88.77.231.38 internal
group-policy GroupPolicy_88.77.231.38 attributes
vpn-tunnel-protocol ikev1 ikev2
dynamic-access-policy-record DfltAccessPolicy
username admin password $sha512$5000$uGR2a+BcSIGyF+2DQ6SCDg==$fYvE4kLh2Ovow5glFci8yw== pbkdf2 privilege 15
tunnel-group 88.77.231.38 type ipsec-l2l
tunnel-group 88.77.231.38 general-attributes
default-group-policy GroupPolicy_88.77.231.38
tunnel-group 88.77.231.38 ipsec-attributes
ikev1 pre-shared-key
ikev2 remote-authentication pre-shared-key
ikev2 local-authentication pre-shared-key
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
no tcp-inspection
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:9230de20cf9acc9467ce562630338828
: end
