First of all, you can take a look at this lesson to see an example of applying NAT to an ASA.
The configuration has some small differences to yours, but should result in the same thing.
Now looking at your configuration, it should work, assuming you are initiating traffic from the inside interface towards the outside interface. Otherwise you will have to create an access list just like in the above lesson to allow such traffic.
One more thing. You will only see translations in the xlat table if you have traffic matching that NAT rule. So you should initiate some pings to activate the rule and then check again for the translations in the table. Let us know how you get along.
Sorry guys for the repeat to my original post ASA5525 NAT, I was trying to update it with my findings but for some reason wasn’t able to. But at any rate here was the fix to my issue:
Problem solved so the reason why I wasn’t able to add the following object NAT
I found your original post and moved your new post into the same thread. Thanks so much for following up on this, it’s of great help and it’s much appreciated!
