I am working with an ATT link between two WAN sites.
Site 1 = JC, connected from 3750G-JC-CORE on interface GigabitEthernet1/0/3
Site 2 = CB, connected from 3750G-CB-CORE on interface GigabitEthernet1/0/28
Our switches are connected via fiber to a ATT’s Ciena hardware at both sites, 1Gb link speed.
However, we pay for a CIR of 100Mb. The rate limiting on my 3750Gs does not appear to be working correctly.
Symptom:
File transfer from a host at JC to a host at CB is very slow when the link speed is 1Gb end-to-end.
If I set the NIC on the host at CB to 100Mb, the file transfer is nearly 10 times faster.
I’m pretty sure I am doing something wrong with rate-limit / shaping / policing on our CPE interfaces that connect to the Ciena hardware.
Here is the relevant config on both interfaces:
S3750G-JC-CORE#sho run int g1/0/3
description ATT OPT-E-MAN CKTID: XXXXXXXX
no switchport
ip address 10.254.20.1 255.255.255.248
rate-limit input 100000000 18750000 37500000 conform-action transmit exceed-action drop
rate-limit output 100000000 18750000 37500000 conform-action transmit exceed-action drop
speed nonegotiate
S3750G-CB-CORE#sho run int g1/0/28
no switchport
ip address 10.254.20.2 255.255.255.248
speed nonegotiate
I am now going to read your lessons on shaping, policing, etc. - but I thought I would post this first.
Thank you!
Kris Jacobs, network admin @ Calhoun County, Michigan
