BGP Conditional Advertising / Advertise MAP
Hello Rene
Please update the lesson on BGP Conditional Advertising / Advertise MAP.
If already in the lesson list, Please share the URL/Link.
regards
Raj
Hello Raj
As far as I know, there is no material yet on BGP conditional advertising. If you would like to suggest a lesson idea, feel free to go to the following link and post your idea. Others on the forum may have also suggested a similar lesson, and you can vote on the lessons you would like to see on the site in the near future.
In the meantime, take a look at these two Cisco documentations that may help you in looking at this particular feature.
As well as some case studies that may help…
Hi raj,
the whole idea of Conditional advertising you could easly find the materials online.
it is used to play a role in multihomed architecture where you will only advertise routes to 1 ISP, if the link faills then the router sees the link down and immediately change to advertise the routes to the 2nd ISP.
you achieve this behavior using route-map and you inherit the route-map into the advertise-map in the bgp command options
for example:
access-list 1 permit host 1.1.1.1
access-list 2 permit any    -    this command is only an example
route-map NEIGHBOR1 permit 10
  match ip address 1
route-map MYROUTES permit 10
  match ip address 2
router bgp 1
  neighbor 2.2.2.2 advertise-map MYROUTES non-exist-map NEIGHBOR1
in the above configuration, the router will check it’s RIB (routing table) and search the host route of 1.1.1.1 as included in the NEIGHBOR1 route-map.
the “non-exist-map” feature will make that process and if the route doesnt exist, the router would advertise neighbor 2.2.2.2 the “MYROUTES” routes included in that route-map.
you could specify any network you want to advertise or in this case I want to advertise everything to neighbor 2.2.2.2.
if the non-exist-map find the route for host 1.1.1.1 then the router wouldn’t advertise anything that included in the “MYROUTES” route-map to neighbor 2.2.2.2.
