Hi I have a quick question I was checking my BGP config to see why my peer router wasn’t learning a particular route. On my router I can see that I am advertising it and that the route is valid and active
se7wancsw20140ha2#sh ip bgp neigh 10.125.7.22 adver
BGP routing table information for VRF default
Router identifier 172.17.7.2, local AS number 65470
Route status codes: s - suppressed, * - valid, > - active, # - not installed, E - ECMP head, e - ECMP
S - Stale, c - Contributing to ECMP, b - backup, L - labeled-unicast
AS Path Attributes: Or-ID - Originator ID, C-LST - Cluster List, LL Nexthop - Link Local Nexthop
Network Next Hop Metric LocPref Weight Path
* > 162.68.200.0/25 10.125.7.21 - - - 65470 65480 ?
* > 162.68.200.128/25 10.125.7.21 - - - 65470 65480 ?
When I go to the peer router and double check all the routes that I am receiving I do not see it.
se7dcicsw10442at#sh ip bgp neigh 10.250.7.21 received-routes
Router identifier 172.17.7.3, local AS number 65480
* > 162.68.176.0/22 10.125.7.21 - - - 65470 i
* > 162.68.180.0/22 10.125.7.21 - - - 65470 i
* 162.68.233.0/25 10.125.7.21 - - - 65470 ?
I checked for access-list on both routers and the only one I see an access-list for is my router se7wancsw20140ha2. The peer router, se7dcicsw10442at, has none. So I am thinking the reason why that is is because both peer are configured for
neighbor SE-755-201-7150S-WAN maximum-routes 12000
neighbor SE-755-201-7150S-TCWANB maximum-routes 12000
and I am reaching the max route that is why the route for
162.68.200.0/25
162.68.200.128/25
isn’t installed in the peer router se7dcicsw10442at. Is my assumption correct and if so how do I verify that?
Warren
