What is LD/RD, RH/RS in show bgp neighbors details
I couldn’t find any relevant information
Hello Network
It seems that Cisco IOS documentation is not adequate for explaining these terms, as it was difficult to find information about this…
Having said that, LD/RD stands for Local Discriminator and Remote Discriminator. A discriminator, according to RFC 5880 which describes BFD, is a non zero value that is used to multiplex and demultiplex BFD packets in the case where there are multiple BFD sessions between two systems. In other words, the discriminator is a value chosen to identify the specific BFD session on the particular device. This is automatically chosen by the BFD negotiation process.
The RH/RS stands for Remote Heard, although the RS is not explained anywhere that I have found. This particular column in the output simply states that the remote BFD neighbor has been heard. In other words, the BFD peering is up.
Some additional configuration documentation you may find useful can be found here:
what does control packet contain in regards to BFD-link failure detection.
Hello Vijay
Take a look at the BFD lesson which explains some of the logic behind the control packets in BFD:
You can also take a look at the detailed structure of the control packets as they are described by the RFC defining BFD at the link below.
Hiii Rene & Laz..
can u explain below bfd config.
bfd-template single-hop FIBRE
interval microseconds min-tx 50000 min-rx 50000 multiplier 3
bfd template FIBRE
isis bfd
Hello Varma
Take a look at this Cisco documentation:
Here you will see that the configuration enters BFD configuration mode for single-hop BFD sessions. This is created for devices that are directly connected. The interval command configures the intervals used for the particular BFD session.
More details about how to create BFD templates and what they actually do can be found at the following link:
hey, need help to understand this,
bfd interval 50 min_rx 50 multiplier 3
bfd echo
bfd all-interfaces
with bfd echo being used, would it be control packets or echo used to monitor the peer status? bfd neigh would go down if it doesn’t hear frm its neigh within 150ms the control packets or echo or both? thanks
Hello Wei Ping
When the echo mode feature is enabled, both control packets and echo packets are sent out at the same time. However, the echo function allows for a reduction in the number of BFD control packets. So yes, both control packets and echo packets are sent out. As stated in the Cisco documentation linked below:
“The echo function and the forwarding engine are responsible for the detection process, therefore the number of BFD control packets that are sent out between two BFD neighbors is reduced.”
A detailed description of this operation can be found at the following Cisco documentation:
Really good article that could come in handy without changing around things.
I’m curious to know if anyone has tested this. I have a ebgp peering session with a provider. I’m looking to temporarily remove the BFD configuration. I was wondering if I remove the BFD configuration without notifying the provider will their router eventually detect that there are some missed BFD packets and therefore tear down the BFD session and also the ebgp adjacency? I tested this out in CML 2.0 but the ebgp adjacency did not go down…only the bfd session was torn down. In the past I have ran into some strange scenarios where I test a use case in CML and the behavior is different in production. If anyone has tested this please let me know. Thanks.
Hello VJnetwork
I labbed this up too, to do some more experimentation, and I have replicated your results. It seems that when you remove the BFD configuration, either by removing the bfd interval command from the interface or by removing the neighbor fall-over bfd command from the BGP configuration, the BGP peering and the resulting routing remains intact.
Now I notice the following. When I disable BFD using one of those methods, I take a look at the syslogs on the other router and I see this:
*Oct 7 06:24:00.698: %BFDFSM-6-BFD_SESS_DOWN: BFD-SYSLOG: BFD session ld:1 handle:1,is going Down Reason: RX ADMINDOWN
However, if I shut down the interface instead, the syslog on the other router displays the following:
*Oct 7 06:29:50.303: %BFDFSM-6-BFD_SESS_DOWN: BFD-SYSLOG: BFD session ld:1 handle:1,is going Down Reason: ECHO FAILURE
*Oct 7 06:29:50.309: %BFD-6-BFD_SESS_DESTROYED: BFD-SYSLOG: bfd_session_destroyed, ld:1 neigh proc:BGP, handle:1 act
Notice in the first case, the reason code is RX ADMINDOWN while in the second case, the reason is ECHO FAILURE. We also get an additional syslog in the second case that states that the BFD session is destroyed, something we don’t see in the first case.
From this info, we can conclude that when you disable BFD, the router informs the BFD neighbor that the action taken was an administrative action, and does not constitute a failure. When the interface is shutdown, that is detected as an echo failure, which is interpreted as a failure on the link, so the BGP session fails too.
(Note that the BGP session, in this case, will fail anyway because the interface goes down, but the exercise does demonstrate how BFD handles an administrative change compared to a real network failure.)
Thus, BFD configurations can be safely removed without the fear of causing a failure or a disruption on a production network.
Thanks for the good lesson. I was able to get BFD running correctly in lab. Is there a best practice timer interval value to use when setting up BFD with an ISP?
Hello Troy
In general, the smaller the interval the better. There are no detrimental effects to using the lowest possible interval when applying BFD.
HI
How can I configure an IP event dampening on an interface?
Hello Giovanni
IP Event dampening is a feature that allows you to configure an exponential decay mechanism to suppress the effects of excessive interface flapping events on routing protocols and routing tables in a network.
For more detailed information about this feature and how to configure it, take a look at this Cisco documentation:
In my opinion, BFD is indeed more efficient than hello packets in OSPF or EIGRP.
But when would we use it?
If link failures are sometimes judged simply because of delays or packet loss.
Does it mean that the routing protocol will always converge due to network status?
Hello TE-EN LIN
BFD should be used wherever super-fast convergence times are necessary. This would definitely be the case at the core of an enterprise network, where even a delay of a few seconds will affect hundreds or even thousands of users. Also, you would want it configured on any network that uses applications that are sensitive to short outages. You wouldn’t care much for email or web users, but for VoIP telephony and videoconferencing, it may cause disruptions that require users to reconnect from scratch, which is not very good. Does that make sense?
I have 2 questions related BFD configuration in IOS XR platform.
As BFD is bidirectional protocol, so they need to configured in both side. But with one-arm-echo we can configure only in 1 device which support BFD. as I know this is IEEE standard. How to configure this protocol in IOS XR platform ?
Other vendor they have static BFD for track and binding to static route.
like below :
bfd for_XXX bind peer-ip 10.10.10.1 vpn-instance OM source-ip 192.168.20.53
discriminator local 106
discriminator remote 206
detect-multiplier 7
min-tx-interval 200
min-rx-interval 200
ip route-static vpn-instance OM X.X.X.X X.X.X.X 192.168.20.54 track bfd-session for_XXX
with this configuration we can control what number discriminator on both side.
is Cisco XR support this features ?
Hello Giarto
Indeed BFD one-arm echo is defined by the IEEE standard and doesn’t require both ends of a link to support BFD. It seems that Cisco doesn’t support this feature. I say “it seems” because I have been unable to find it stated explicitly. However, Cisco documentation does state the following about BFD:
Cisco supports the BFD asynchronous mode, in which two routers exchange BFD control packets to activate and maintain BFD neighbor sessions. To create a BFD session, you must configure BFD on both systems (or BFD peers).
This seems to indicate that both ends of the link must support BFD, thus we can come to the conclusion that one-arm echo is not supported.
Cisco supports this feature as well, and you can find out how to apply it at the following Cisco documentation:
Hope you are well.
I was testing the below scenario in LAB and faced this issue:
SW Product: ASR9K-x64-iosxr-px-7.3.2.tar
HW Product: ASR-9910
The issue appears when we create multiple static routes with different BFD intervals for the same next hop in a single commit. It throws an error; however, the configuration is committed.
If we create them in two different commits, then 2nd commit should fail and it’s failing as expected.
RP/0/RSP0/CPU0:RCPXY90321#conf t
RP/0/RSP0/CPU0:RCPXY90321(config)#router static
RP/0/RSP0/CPU0:RCPXY90321(config-static)# vrf CUSTNET
RP/0/RSP0/CPU0:RCPXY90321(config-static-vrf)# address-family ipv4 unicast
RP/0/RSP0/CPU0:RCPXY90321(config-static-vrf-afi)# 10.3.216.113/32 10.3.216.108 bfd fast-detect minimum-interval 1000 multiplier 4 description PXY9-SCM-TEST-0001,VLAN757
RP/0/RSP0/CPU0:RCPXY90321(config-static-vrf-afi)# 10.3.216.114/32 10.3.216.108 bfd fast-detect minimum-interval 300 multiplier 3 description PXY9-SCM-TEST-0001,VLAN757
RP/0/RSP0/CPU0:RCPXY90321(config-static-vrf-afi)# !
RP/0/RSP0/CPU0:RCPXY90321(config-static-vrf-afi)#!
RP/0/RSP0/CPU0:RCPXY90321(config-static-vrf-afi)#root
RP/0/RSP0/CPU0:RCPXY90321(config)#sh com ch diff
Fri Jun 23 00:35:08.391 AEST
Building configuration...
!! IOS XR Configuration 7.3.2
router static
vrf CUSTNET
+ 10.3.216.113/32 10.3.216.108 bfd fast-detect minimum-interval 1000 multiplier 4 description PXY9-SCM-TEST-0001,VLAN757
+ 10.3.216.114/32 10.3.216.108 bfd fast-detect minimum-interval 300 multiplier 3 description PXY9-SCM-TEST-0001,VLAN757
RP/0/RSP0/CPU0:RCPXY90321(config)#commit label post_3784517_SR_1_20230622
EndFri Jun 23 00:35:23.745 AEST
% Failed to commit one or more configuration items. Please issue 'show configuration failed [inheritance]' from this session to view the errors
RP/0/RSP0/CPU0:RCPXY90321(config)#sh configuration failed
Fri Jun 23 00:35:40.253 AEST
!! APPLY ERRORS: This configuration was accepted by the system,
!! but errors occurred when the system attempted to make the
!! configuration operational. The individual errors for each
!! failed configuration command can be found below. These errors
!! will cause an inconsistency between the system's running
!! configuration and its operational state, which may be addressed
!! by using the 'no' form of the command to remove it from the
!! running configuration.
router static
vrf CUSTNET
!!% 'ip-static' detected the 'warning' condition 'Nexthop is already configured with different interval or multiplier or multihop'
End
P/0/RSP0/CPU0:RCPXY90321#show running-config router static vrf CUSTNET address-family ipv4 unicast
Fri Jun 23 00:36:13.855 AEST
router static
vrf CUSTNET
RP/0/RSP0/CPU0:RCPXY90321#sh configuration commit list 5
Fri Jun 23 00:37:54.348 AEST
SNo. Label/ID User Line Client Time Stamp
1 post_3784517_SR_1_20 d950235 vty25:node0_RSP0_C CLI Fri Jun 23 00:35:23 2023
2 del_SR_230623003056 n113009 vty27:node0_RSP0_C CLI Fri Jun 23 00:31:01 2023
3 del_HSRP_20230623003 n113009 vty27:node0_RSP0_C CLI Fri Jun 23 00:30:46 2023
4 SR_230623001739 n113009 vty25:node0_RSP0_C CLI Fri Jun 23 00:17:43 2023
5 HSRP_757_20230623001 n113009 vty25:node0_RSP0_C CLI Fri Jun 23 00:16:59 2023
RP/0/RSP0/CPU0:RCPXY90321#sh configuration commit changes post_3784517_SR_1_20
Fri Jun 23 00:38:30.037 AEST
router static
vrf CUSTNET
End
Logs:
logs_Static route BFD issue.txt (1.1 MB)
show tech files:
untitled folder.zip (1.5 MB)
Thanks in Advance
Manami
