Is there a reason why BGP Aggregation (section 3.7.6 of the CCIE R&S lab blueprint) not covered under BGP in the CCIE R&S section of the website? Is it covered anywhere else on the site? Thanks,
Hello Mo,
I have an example for BGP aggregation AS-SET here:
I’ll see if I can create a general BGP aggregation example and add it to 3.7.6.
That would be great, since there are many other command arguments. The AS-Set example you listed is excellent. Thank you.
