HI,
Thank you for the link. Im still kind of stuck and wondered if you can point me in the right direction please. I have a cisco 2821 router with a gig0/0 interface plugged into the cisco asa 5510 ethernet 0/0 port. I have pasted in the asa config in hopes that you might see what might be wrong. i cannot ping from the router to the asa. both are in the 192.168.2.0 subnet. i tried both straight and cross over after hearing that asa interfaces dont have the auto sensing mdix stuff. could you let me know what my issue is please.
ciscoasa# sh running-config
: Saved
: Serial Number: xxxxx
: Hardware: ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
ASA Version 9.1(7)12
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0/0
no nameif
security-level 100
interface Ethernet0/1
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
ftp mode passive
pager lines 24
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-762-150.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username ADMIN password WpmDdjXRzvy3bJoo encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:20f9079b68e70577a4883cc406ee836d
: end
ciscoasa#
