I’m having trouble installing asdm and configuring it. I see that my ASA has asdm software disk0:/asdm-713.bin. The ASA is Cisco Adaptive Security Appliance Software Version 9.1(2). I checked the specs for java and got jre8 561. Not sure what else I should look at. My laptop is connected to the inside. Inside address is 10.0.0.254. I tried to browse to https://10.0.0.254 and it times out. Any help would be appreciated. Thanks.
Take a look at the following lesson that details how to set up ASDM on an ASA and see if following these steps will resolve your issue:
In addition, this official document from Cisco describes in detail all the requirements for using ASDM 7.13(x).
I have found that Java has been the biggest headache for me when configuring ASDM, as particular versions of the runtime environment need to be installed, often requiring a downgrade to get it to work. However, in your case, you are seeing a timeout, which itself seems to indicate a network issue. Take a look at the various notes and compatibilities in the shared document. Also I suggest you use some debugs on the ASA to see if you are actually reaching the ASA and what kind of error message may appear. A particular lesson that may help you in this troubleshooting is the following:
The connection for this site is not secure 192.168.1.1 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Unsupported protocol
The client and server don't support a common SSL protocol version or cipher suite.
This error message appears on your web browser when you attempt to connect to the ASA, correct? If so, this is typically a problem that appears when the browser is set to accept only certain security parameters.
Take a look at this Cisco community thread to see if there are parameters that you can change to get it to work.
Another option would be to try a different browser. Or you could do a search online for the ERR_SSL_VERSION_OR_CIPHER_MISMATCH error on a browser, and there are many different configurations that you can apply to get it to work.
Hey thanks a lot for your help. I finally got it working. I did a lot of research from your suggestions. I was able to telnet to it and ssh to it. I did some debugs. I did some research to tls and different browsers. I finally went to firefox which seemed like the easiest to work with and was able to download the asdm and install it on an old laptop that I had laying around. I’m so happy. Thanks guys!
