I am not able to figure out the best method to NAT because there are so many options..
In ASDM > When do I use “add object wth NAT option” and when do I use “add NAT rule”
for example:
I would like to set up an FTP server (DMZ) and give it its own IP on the OUTSIDE + The FTP server needs to see the IP of the FW (and not original source)
thanks in advance,
S
PS: Which tool do you use to create the topology picture?
