Cisco ASA NAT Port Forwarding
Hello @agrozdanov,
Like Lazaros mentioned, this is the default policy-map on the ASA. It’s not needed for this lesson so I’ll get rid of it.
Thank you Laz !
Best,
Asen
Thank you Rene !
Best,
Asen
I may need some clarity on the output below if I am mistaken. What I have found says if the connection is initiated from the outside address you will see this as an untranslated_hit because this is a mapped IP to real translation. Is this correct?
(DMZ) to (outside) source static SSH_SERVER interface  service tcp ssh 10022
    translate_hits = 0, untranslate_hits = 1
Hello Donald
Yes you are correct. An translate hit is one that takes place in the “forward direction” or the direction of the interfaces specified in the NAT rule. An untranslate hit is one that takes place in the opposite direction. The following documentation describes it in great detail, and should clarify any further questions you may have:
I’ll read the Cisco doc. Thanks for the link.
Hi Rene ,
I Have problem in this topic port forwarding I want to forward 3 port to server in dmz i have public ip for this server i use this config i put the 3 port object serves group anad i create object network :
object network x
host x.x.x.x
(dmz) to (outside) source static service object  y.y.y.y public ip
the result only one port working i trace the packet all phase ALLOW but only one port is working
Hello Mohamed
You have to make sure that you include all three ports in the access lists that you create. For example, if the ports you want to forward are TCP ports 80 81 and 82, then you must ensure that you have created the appropriate objects, and have the following access lists:
access-list MY_SERVER extended permit tcp any host 192.168.1.10 eq 80
access-list MY_SERVER extended permit tcp any host 192.168.1.10 eq 81
access-list MY_SERVER extended permit tcp any host 192.168.1.10 eq 82
…assuming the IP address of your server is 192.168.1.10.
Hi Rene!
Can we port-forward another tcp port to same server? For example, I want to port-forward both TCP ports 22 and 443 to same server 192.168.3.3.
When I add the 2nd NAT statement, it replaces the 1st NAT as though the ASA doesn’t allow more than one NAT statement of each type, TCP or UDP.
Hello Ahmad
You can achieve what you want by creating two objects with the same IP address. For example:
ASA1(config)# object network HTTPS_SERVER
ASA1(config-network-object)# host 192.168.3.1
ASA1(config-network-object)# nat (DMZ,OUTSIDE) static interface service tcp 443 443
ASA1(config)# object network SSH_SERVER
ASA1(config-network-object)# nat (DMZ,OUTSIDE) static interface service tcp 22 22
Only one NAT statement can be assigned within an object, but you can create multiple objects using the same IP address.
Hi ,
How would I implemented port forwarding if I am using a multi context ASA and would like to use a public IP that I own ( instead of the ASA outside interface ) for the NAT translation between the outside and the subnet my private server resides on ? Thank you
Hello Hassan
Your scenario involves the combination of several technologies and features. First, you have to keep in mind that:
  • In a multi-context implementation, each context functions as a completely separate ASA, each with its own interfaces, routing table and NAT rules. That means that if you want to implement NAT with a public IP, you can only do it on one of the two contexts.
  • On the context you choose to implement it, you don’t have to assign that public address to the outside interface. In other words, the outside interface IP and your owned public IP may be different. That’s fine as long as the upstream device (your ISP’s device) routes the owned public IP to the ASA.
If you keep those in mind, then configuration takes place in the same fashion as you would do it for a single ASA. Is there something specific that you would like us to examine further? Let us know!
I am good now . Thank you for the clarification .
