Cisco ASA Site-to-Site IKEv2 IPSEC VPN
Hello Hong
In this particular case, the ASAs are directly connected. The next hop is actually the other ASA. But even if there were other routers in between the two ASAs, the command would still be the same. Why? Because we are telling the local ASA specifically how to reach the subnet behind the remote ASA. It is assumed that the ASA, if connected to the internet, would already have a default route to the ISP router. However, we want this destination network to be sent directly to the outside interface of the remote ASA.
This might sound a little bit strange, configuring a static route with a destination IP address that is not directly connected. But this is acceptable. What will happen in this case is recursive routing.
If you have a router in bridge mode I assume you mean that it is passing traffic at layer 2, and not performing routing or any other layer 3 function. If this is the case, then there shouldn’t be any problems with such a setup. Just make sure that the outside interface of the ASA still has a routable (non-private) IP address and it is reachable from the other ASA. Also ensure that the router is passing through IPSec traffic (no filtering should take place).
These are just general guidelines based on the information you shared. There may be more parameters involved that may affect the operation of an IPSec VPN, so it all depends on the specifics of the setup. Let us know how you get along, and if we can be of further assistance.
Hello Rene/Laz,
How can I configure two IKEv2 IPsec Site to Site VPN tunnel on HQ-ASA-FW for the same destination encryption domain (10.0.0.0/24) so where one tunnel (to 2.2.2.2) will be acting as Active tunnel and another one (to 3.3.3.3) will be Standby tunnel?
Thanks a lot.
Hello Azm
Hmm, this is an interesting setup! It’s actually not too hard to do, the configuration is quite straightforward. The ā€œtrickā€ here is to use the same ACL for traffic selection for both crypto maps, so that both tunnels will select the same ā€œinteresting traffic.ā€
The other key is to configure SLA monitoring to track the primary tunnel for failover to the secondary tunnel.
Here are some key points that you should keep in mind:
  • Define two IKEv2 policies, proposals, keyrings, profiles as you would when creating two separate tunnels.
  • Define the IPSec transform set you will be using. You can define one for each of the tunnels, or a single transform set that will be referenced by both tunnels.
  • Define the IPSec profiles, one for each tunnel.
  • Define the ACL that will match interesting traffic. This ACL will be used by both tunnels.
  • Creat a crypto map that will configure both the primary and secondary tunnels under the same sequence.
  • Apply the crypto map on the outside interface.
  • Configure SLA monitoring for failover using an ICMP echo to monitor the status of the primary tunnel.
  • Finally, you can configure static routing with tracking, so that the SLA will affect which tunnel will be used to route traffic destined for the destination network.
Some lessons that will help you out in the above include:
https://networklessons.com/cisco/ccie-enterprise-infrastructureip-sla-service-level-agreement-on-cisco-ios
https://networklessons.com/cisco/ccie-enterprise-infrastructurereliable-static-routing-with-ip-sla
https://networklessons.com/cisco/ccie-enterprise-infrastructureipsec-internet-protocol-security
For site to site IKEv2 route-based VPN tunnel, do I have to configure no-nat and bidirectional access-list to allow bidirectional traffic in addition to below configuration:
crypto ipsec ikev2 ipsec-proposal Tun-Prop
 protocol esp encryption aes-256
 protocol esp integrity sha-512
crypto ipsec profile Tun-Prof
 set ikev2 ipsec-proposal Tun-Prop
 set pfs group21
 set security-association lifetime seconds 3600
crypto ikev2 policy 10
 encryption aes-256
 integrity sha512
 group 21
 prf sha512
 lifetime seconds 28800
crypto ikev2 enable outside
group-policy Tun-Grp-Pol internal
group-policy Tun-Grp-Pol attributes
 vpn-tunnel-protocol ikev2
tunnel-group 131.226.X.X type ipsec-l2l
tunnel-group 131.226.X.X general-attributes
 default-group-policy Tun-Grp-Pol
tunnel-group 131.226.X.X ipsec-attributes
 ikev2 remote-authentication pre-shared-key SuperSecret
 ikev2 local-authentication pre-shared-key SuperSecret
interface Tunnel1
 nameif P81_131.226.X.X
 ip address 169.254.2.122 255.255.255.252
 tunnel source interface outside
 tunnel destination 131.226.X.X
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile Tun-Prof
route P81_131.226.X.X 10.255.0.0 255.255.0.0 169.254.2.121
access-group OUTSIDE-ALLOW-IN in interface outside
access-group INSIDE-ALLOW-IN in interface inside
access-group P81_131.226.X.X in interface P81_131.226.X.X
Thanks in advance!!!
Hello Azm
In a site-to-site IKEv2 route-based VPN tunnel, you do not necessarily need to configure NAT Exemption (i.e. no-NAT) or bidirectional access-list to allow bidirectional traffic. The traffic is allowed based on the routing table, not access-lists.
However, in some specific scenarios, you might need to configure NAT Exemption or use access-lists to control the traffic. For instance, if you have overlapping IP address spaces between the two sites, you would need to use NAT to translate the IP addresses. Similarly, if you want to restrict certain traffic over the VPN, you can use access-lists.
The configuration you have posted seems correct for establishing a basic IKEv2 route-based VPN tunnel. Just make sure that the networks you want to reach are correctly routed through the tunnel interface (using static routes or a routing protocol).
In addition, don’t forget to configure the necessary ACLs to allow the VPN traffic. The access-group commands you posted suggest that you have already configured these, but make sure that the rules allow the necessary VPN traffic.
I have a multi context ASA code on version 9.22 and trying to build a site to site VPN with Azure. Can you please provide advice on the following?
What would be the best to implement inter context communication when the Azure site to site vpn traffic coming on the outside interface of Context A is destined to a network located in context B?
Hello Hassan
The first thing to keep in mind has to do with ASA version numbers and supported features. Initially, I was not quite sure if your version supported site-to-site VPNs in multiple context mode, but after looking at this Cisco documentation, I have confirmed that it does support it.
Now, having said that, and keeping in mind that contexts in ASAs act as completely isolated virtual firewalls, you must create an external transit path. You can do this by allocating a physical interface (or subinterface) to both contexts, with each context having its own IP address on a shared transit subnet. More details can be found in this section of the previously linked document.
From a high level perspective, this is the approach that can be followed:
  1. Azure VPN terminates in Context A on its outside interface
  2. Context A decrypts the traffic
  3. Traffic destined for Context B networks is routed to a transit interface
  4. Traffic exits Context A on the transit interface and re-enters Context B on its side of the transit interface
  5. Context B routes the traffic to the final destination
  6. Return traffic follows the reverse path
One beneficial approach is to use the idea of Cascading Contexts, as described in the linked document. This places one context (context A) directly in front of another (context B) where the outside interface of one context is the same interface as the inside interface of the other context. This simplifies the configuration by configuring shared parameters in the ā€œtopā€ context.
Ultimately, regardless of the Azure portion of your topology, the focus should be on the most appropriate way to enable inter-context communication, which you can achieve using the general principles and links I shared. If you need to go more in-depth, please provide us with more of your parameters and requirements so we can help you further.
