You have uploaded Frame-Relay tutorial under EVN. Please re-upload the correct one.
Best Regards,
Ronnie
Hi Ronie,
You beat me to it…I published the post so I could link to it from the VRF lite post. Anyway I wrote it now and it’s online…hope you like it!
Really good explanation. VRF lite as DMVPN is new in CCNP route, so it’s good to learn about it. Thanks for your work.
However, are you going to update your CCNP books? Because I’d like to buy them, thanks to your straightforward explanation.
Daniel B.
Hi Daniel,
Glad to hear you like it. The books are up-to-date btw, all 3 of them.
awesome i never thought i would understand EVN this easily..
i have one question Rene, on ISP1, when you show the route of RED and BLUE, it doesnt know the OSPF route to GREEN, but when you show the route of GREEN, it knows the route to RED and BLUE?
they all have the same config, you just route replicate from GREEN to BLUE and RED, then route replicate from BLUE and RED to GREEN. you still not use the redistribution but GREEN knows the OSPF route? whilst the BLUE and RED didnt know, thats why you ran the Redistribution process, so Red and BLUE now knows the ospf route to Green.
ohh now i understand why is that. sorry for this post, i just observed the ip routes of different vrfs and now i understand.
thanks for this awesome lesson!
Thank you Rene.
Also you can try from one of the ISP routers to run “show ip ospf route”. It gives you the best route to a destination, next hop, outgoing subinterface, how many time SPF was executed, etc…
Best, MS
Hi Marty,
That’s a very useful command indeed.
Simply Awesome! Your lessons are articulate and useful. Thank You Rene.
Rene: This is an excellent post. Pretty clear and straightforward. Thanks for the knowledge.
On a side note, i think we can avoid configuring OSPF instance 3 in VRF Green, if we would like to redistribute “connected” subnets into RED and BLUE while replicating routes. I mean as below
router ospf 1 vrf RED
redistribute vrf SHARED_INFRA connected.
I tried and this works. Let me know if this is not valid of applying ? Thanks again.
Hi Siva,
That sounds like a valid solution yes.
Rene, great tutorial ! Is there a way i could find the configs text for all the routers ?
For sure, I just added the configs.
ISP1#show ip routes vrf Blue
L + 192.168.2.254 is directly connected, GigabitEthernet2
why it shows 192.168.2.254 (in vrf RED)? Is it from vrf GREEN route-replicate?
Hi Collin,
That’s right, it’s a little side effect of replicating everything. All routes are replicated from blue/red to green and vice versa.
To solve this, it’s better to use a route-map to define what should/shouldn’t be replicated:
ISP1(config-vrf-af)#route-replicate from vrf Green unicast all route-map RED_PREFIXES
really nice explanation. Thanks for it.
I have one question about config:
Lets say i dont want to use EVN to configure trunk between ISP1 and ISP2. How does the router know it shloud use VRF Blue with tag 10 and not 20?
Is there another command to use?
Thanks you ![]()
EVN only knows what tags to use since we configured the tags on the VRFs.
Also, it basically only does this for us:
interface GigabitEthernet3.10
description Subinterface for VNET Blue
encapsulation dot1Q 10
vrf forwarding Blue
ip address 192.168.56.5 255.255.255.0
The sub-interface above was created by EVN. If you don’t want to use EVN, you could configure sub-interfaces like this yourself.
OK, thanks.. now it is clear for me because we configure VRF and tag under interface configuration
That is i was confused about.
I can’t seem to get an ospf neighborship across the evn trunk. I’ve looked over my config 3 or 4 times and cannot figure out why.
Blue1#sh run
Building configuration...
Current configuration : 1229 bytes
! Last configuration change at 01:20:27 UTC Fri May 5 2017
version 15.6
no platform punt-keepalive disable-kernel-core
platform console serial
hostname Blue1
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
subscriber templating
license udi pid CSR1000V sn 9J8YYZOLADL
spanning-tree extend system-id
redundancy
interface GigabitEthernet1
negotiation auto
interface GigabitEthernet2
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
interface GigabitEthernet4
no ip address
shutdown
negotiation auto
router ospf 1
virtual-service csr_mgmt
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
alias exec srs sh run | s router
line con 0
stopbits 1
line vty 0
login
line vty 1
login
length 0
line vty 2 4
login
Blue1#
Red1#sh run
Current configuration : 1228 bytes
! Last configuration change at 01:23:05 UTC Fri May 5 2017
version 15.6
hostname Red1
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
license udi pid CSR1000V sn 97QJRXFRQP2
redundancy
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 2
network 192.168.2.0 0.0.0.255 area 0
no ip http server
control-plane
line con 0
stopbits 1
line vty 0
login
line vty 1
login
length 0
line vty 2 4
login
Red1#
ISP1#sh run
Current configuration : 1676 bytes
! Last configuration change at 01:32:03 UTC Fri May 5 2017
version 15.6
hostname ISP1
boot-start-marker
boot-end-marker
vrf definition Blue
vnet tag 10
address-family ipv4
exit-address-family
vrf definition Red
vnet tag 20
address-family ipv4
exit-address-family
no logging console
no aaa new-model
license udi pid CSR1000V sn 9DJH6OB907Y
redundancy
vrf forwarding Blue
negotiation auto
vrf forwarding Red
negotiation auto
vnet trunk
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 1 vrf Blue
network 192.168.56.0 0.0.0.255 area 0
router ospf 2 vrf Red
no ip http server
control-plane
alias exec dc3 show derived-config | b GigabitEthernet3
line con 0
stopbits 1
line vty 0
login
line vty 1
login
length 0
line vty 2 4
login
ISP1#
ISP2#sh run
Current configuration : 1657 bytes
! Last configuration change at 01:39:55 UTC Fri May 5 2017
version 15.6
hostname ISP2
boot-start-marker
boot-end-marker
vrf definition Blue
vnet tag 10
address-family ipv4
exit-address-family
vrf definition Red
vnet tag 20
address-family ipv4
exit-address-family
no aaa new-model
license udi pid CSR1000V sn 98KHYWG4AV9
redundancy
vrf forwarding Blue
ip address 192.168.3.254 255.255.255.0
negotiation auto
vrf forwarding Red
ip address 192.168.4.254 255.255.255.0
negotiation auto
vnet trunk
ip address 192.168.56.6 255.255.255.0
negotiation auto
no ip address
shutdown
negotiation auto
network 192.168.3.0 0.0.0.255 area 0
network 192.168.4.0 0.0.0.255 area 0
no ip http server
control-plane
line con 0
stopbits 1
line vty 0
login
line vty 1
login
length 0
line vty 2 4
login
ISP2#
Blue2#sh run
! Last configuration change at 01:23:16 UTC Fri May 5 2017
version 15.6
hostname Blue2
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
license udi pid CSR1000V sn 91RY9ZNDXH1
redundancy
ip address 192.168.3.3 255.255.255.0
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 1
no ip http server
control-plane
line con 0
stopbits 1
line vty 0
login
line vty 1
login
length 0
line vty 2 4
login
Blue2#
Red2#sh run
! Last configuration change at 01:23:20 UTC Fri May 5 2017
version 15.6
hostname Red2
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
license udi pid CSR1000V sn 9XQ8OPC55ZT
redundancy
ip address 192.168.4.4 255.255.255.0
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
router ospf 2
no ip http server
control-plane
line con 0
stopbits 1
line vty 0
login
line vty 1
login
length 0
line vty 2 4
login
Red2#
