According to Cisco, IPv6 is not supported on an EVN trunk, except on vnet global. This is a predefined EVN which refers to the global routing contect and corresponds to the default RIB. For more information about EVN and it’s support or IPv6, take a look at this documentation:
EVN is still useful especially when running multiple isolated networks end-to-end over the same L3 infrastructure. Many of the benefits of this technology can be found at the following Cisco documentation.
Very interesting topic…I enjoyed it. My question is , what will the configuration look like if I want to use EIGRP instead of OSPF? I tried using EIGRP but could not find the vrf commands. Thank you.
When configuring VRFs with EIGRP, the commands used are somewhat different than those for OSPF. In OSPF, you issue the command per OSPF process. This means that the VRF is actually appended as a keyword to the router command like so:
ISP1(config)#router ospf 1 vrf Blue
ISP1(config)#router ospf 2 vrf Red
So there is a one to one correspondence between OSPF processes (1 and 2 in the above commands) and the VRFs.
With EIGRP on the other hand, you configure the VRFs on a per address-family basis. This means that the command for specifying the VRF is placed in the address-family command like so:
ISP1(config)# router eigrp 1
ISP1(config-router)# address-family ipv4 vrf Blue
ISP(config-router-af)# network 172.16.0.0
ISP1(config-router)# address-family ipv4 vrf Red
ISP(config-router-af)# network 172.17.0.0
If you want to configure this without EVN, then you must create two subinterfaces on each of the Gi3 interfaces of the ISP routers, and connect them with separate subnets. If you look at the lesson, the vnet trunk command actually works as a macro to create the actual configuration you need. So the configuration on the Gi3 interface that you are looking for is already in the lesson:
HI ;
I created sub interfaces but ı cannot ping . İf Iconfigurate mpls ip under interface e0/2 , I can ping. İs there anything i need to add for pinging ?
TK-1#ping 10.10.20.20 source 172.29.10.1
Sending 5, 100-byte ICMP Echos to 10.10.20.20, timeout is 2 seconds:
Packet sent with a source address of 172.29.10.1
TK-1#tra
TK-1#traceroute 10.10.20.20
Tracing the route to 10.10.20.20
1 172.29.10.254 1 msec 0 msec 1 msec
2 * * *
3 * * *
4 * * *
ISP-1(config-subif)#
interface Ethernet0/2
interface Ethernet0/2.10
description subinterface for TK
encapsulation dot1Q 10
ip vrf forwarding TK
interface Ethernet0/2.20
encapsulation dot1Q 20
ip vrf forwarding TEKNIK
ISP-2(config-subif)#
TK-1#show ip route ospf
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
O IA 10.10.20.20/32 [110/21] via 172.29.10.254, 02:56:49, Ethernet0/0
20.0.0.0/24 is subnetted, 1 subnets
O E2 20.20.10.0 [110/1] via 172.29.10.254, 03:19:50, Ethernet0/0
172.29.0.0/16 is variably subnetted, 3 subnets, 2 masks
O IA 172.29.20.0/24 [110/11] via 172.29.10.254, 02:56:49, Ethernet0/0
Yes you are correct. In the configuration that the EVN command produces, there is an additional command that you are unable to implement on your system due to the limitations of EVE, and that is the vnet trunk command that is found within the physical interface configuration. This command actually allows the single IP address on the trunk interface of the router. This results in the same trunk interface being identified by the same IP address in different EVN contexts. As described in the following Cisco documentation, each EVN has a unique routing and forwarding table, enabling support for overlapping IP addresses across multiple EVNs.
Without the vnet trunk command in the physical interface, this is not possible. So you must create subinterfaces with different IP subnets for each subinterface link.
Great lesson, I`ve been following the lab on my simulator with c7200 router and it works!!!, my question is, EVN can be implemented only on Cisco routers, or it can be integrated with other brands?, in other words EVN is cisco propietary feature?
The second one is if you are following a design with Routers using EIGRP as well as EVN, and the other side of the design is using OSPF as well as EVN, you can redistribute the routes between each other?, or it is not necessary to do that kind of combination?
EVN is not Cisco proprietary. It’s simply VRF-lite over VLAN point-to-point subinterfaces. The EVN name is Cisco’s naming of the feature, but you can easily connect a Juniper or HP device on the other end of the link and it will work fine, as long as it is configured correctly on its end.
As for your second question, in order to perform redistribution between EIGRP and OSPF, you need to choose which router on which end will perform the redistribution. You can’t have OSPF on one end and EIGRP on the other, but you must have a single router with at least one interface in the OSPF domain and another in the EIGRP domain. Such a configuration is independent of the EVN configuration, but you can implement EVN and this kind of redistribution on the same device…
Hello Laz ,
my Question is about this Command : redistribute vrf Green ospf 3 subnets . How does Router recognize this replicated Route as Ospf 3 Route although this Route (5.5.5.0 ) is as directly connected replicated Route inside VRF Red , Blue ?
Notice that on ISP1, when VRF Green was created, an OSPF process was also initiated on the Green VRF:
ISP1(config)#router ospf 3 vrf Green
ISP1(config-router)#network 5.5.5.0 0.0.0.255 area 0
These commands initiated an OSPF process to share these specific subnets. Yes, the subnet itself is directly connected to ISP1, but you’re telling the router to advertise it.
As we have seen until now, by default routing protocols will not share routing information between VRFs unless you redistribute them. So by issuing the following commands:
ISP1(config-router)#redistribute vrf Green ospf 3 subnets
…you are stating that you want to share all networks advertised within OSPF process 3 (which is the network off of L0). Thus, the 5.5.5.0/24 subnet is successfully redistributed into Red and Blue.
EVN and GRE are technologies that can work together. EVN relies on VRFs to segment network traffic. GRE tunnels on the other hand, encapsulate traffic, including VRF-specific data, making them compatible. VRFs can be bound to GRE tunnel interfaces, and EVN’s routing protocols (e.g., OSPF) function over GRE tunnels when properly configured.
What you ultimately want to achieve with the use of GRE and EVN together depends upon your requirements, but they can indeed be used together.
I created a GRE tunnel, but it does not let me enable EVN like you would on a standard interface. Is this normal? Are you saying you would need to make individual GRE tunnels for each VRF and then use OSPF or something for routing? My thought process was to try and make a GRE tunnel so I could have a GRE trunk basically caring all the VRF data like the standard port would.
Thanks for the response and the info. I haven’t had personal experience in the implementation of this particular setup you are suggesting, and I find that there is very little documentation concerning this. However, it seems that EVN isn’t supported directly on GRE tunnel interfaces the way it is on physical interfaces. GRE doesn’t act as an EVN trunk in the same way a standard port does.
The key here is that EVN relies on the ability to tag traffic with VNET tags and operate over physical or subinterfaces that support this tagging, something GRE tunnels apparently don’t natively support.
So yes, if you want to simulate EVN-like behavior over GRE, you may need to implement it manually. It could also have to do with the OS version of the IOS being used. I suggest you further experiment with this if you have the opportunity, it’s an interesting situation!
I hope this has been helpful, and I wish it could have been more helpful…
I know I’m fairly late to this party, but I had recently (couple months now) started relearning and studying to take my CCNP ENCOR and ENARSI. I just wanted to say that so far I’ve been extremely impressed and happy with how easy NetworkLessons has been to understand as a resource.
That being said, with being so late and I know some of the lessons are older than the other, but moving to this lesson from the VRF Lite lesson was only slightly jarring with command updates. I know it’s such a tiny thing and easy to look it up, but knowing myself it sidetracked my pacing to make sure I somehow didn’t miss something or if this is just a completely different command compared to the other.
I just think it would be good to add that little note to the command update so it might happen less.
Command in question: ISP(config-if)#ip vrf forwarding ...
being slightly shortened to remove the ip and updated to: ISP(config0if)#vrf forwarding...
Like I said, very small thing, for me at first I thought it was changing what was being configured but after a quick search I figured it was just the same exact command just shorter!
Great to have you with us, and no worries, there’s no problem with coming late to the party!! Good for you for setting the goal of getting your CCNP certification. I’m glad you found NetworkLessons a helpful resource.
It’s good that you bring this up, because this is not simply a change in syntax. It is a move by Cisco to design its devices to conform to features that support multiple address families, that is, both IPv4 and IPv6.
The legacy configuration uses ip vrf simply because it was originally designed for IPv4. This was a simpler configuration structure that defines the VRF only in the context of IPv4, simply because IPv6 was not yet supported.
With the more modern mulit-protocol VRF support (i.e. IPv4 and IPv6), using just vrf allows the support of multiple address families. The command is protocol-agnostic. When you use this command, no protocol is yet chosen. The protocol that will be used for that VRF is later defined using the address-family command under the vrf definition configuration mode.
Now, having said that, you should be comfortable with using both syntaxes, especially for certification exams, as either syntax may be used.
Thanks for your suggestion, though. Adding a note about this command in the lesson may be helpful. I will let @ReneMolenaar know to consider making any additions and clarifications to the lesson based on this.
