I am doing a test for prioritizing SSH and Port 60 traffic using bandwidth shape up to 1.5 Mbps over 2 Mbps backhaul link, other traffic should pass through remaining BW = 512 kbps, and I would apply this QoS (service policy) in backhaul router WAN interface. how do I achieve this with Cisco QoS.
Hello Sivakumar
I suggest you go through Rene’s section on QoS and traffic shaping and see if you can apply some of the concepts there to your topology. Take a look at:
as well as at the various other QoS lessons.
Once you make your attempt, if you hit a snag or have any more specific questions, we’re here to help!
Thanks for the reply. Yes I gone through Rene’s Qos shaping, but that steps will not work in 15(4) IOS, I can’t associate service policy directly to the interface instead need to create parent child policy and associated to the interface. Please help to create Parent child policy where I can prioritize and BW shaped
Hi Sivakumar,
You can’t configure a priority queue and shape in a single policy-map. You’ll need a nested policy for that. Here’s an example:
ip access-list extended TCP_60
permit tcp any any eq 60
class-map match-any PRIORITY
match access-group name TCP_60
match protocol ssh
policy-map PRIORITY
class class-default
priority 1000
policy-map SHAPER
class PRIORITY
shape average 1500000
service-policy PRIORITY
The parent policy is a shaper for SSH / TCP 60 traffic and it shapes up to 1.5 Mbps. The sub-policy (PRIORITY) has a priority queue. I’ve set it to 1 Mbit.
All SSH / TCP 60 traffic is shaped up to 1.5 Mbit and prioritized up to 1 Mbit. Why do you want to shape up to 1.5 Mbit btw? Do you want to prevent drops from when you exceed 2 Mbit?
In that case, it would make more sense to configure it like this:
policy-map SHAPE_ALL
class class-default
shape average 2000000
policy-map PRIORITY
class PRIORITY
priority 1500
Now you shape everything up to 2 Mbit. Within the shaper, the sub-policy adds a priority queue for your SSH and TCP_60 traffic.
