Trying to add Palo Alto as an available node. Keep getting hung up on node definition. Does anyone have documentation for CML and this process (it is different than VIRL)
Hello Scott
From the little research, I was able to do, it seems that CML is able to run anything that will run in KVM, and Palo Alto does run on KVM. Without having found anything definitive, there are some resources concerning this issue at the following Cisco Learning Network threads that might help point you in the right direction:
