what does mean the command under bgp protocol no ipv4 unicast
if no write no ipv4-unicast what’s happen ?
thanks
Hello Ugo
If I’m not mistaken you mean the no bgp default ipv4-unicast command.
The bgp default ipv4-unicast command will set the IPv4 unicast address family as the default for BGP peering session establishment. This is actually the default behaviour for each BGP session that is configured with the neighbor remote-as command. By issuing the no version of the command, you are essentially enabling multi protocol GPB mode, where multiple address families can be negotiated during the BGP session setup.
Now from what I read, it may no longer be necessary in newer versions of IOS as the default behaviour of BGP has been changed to be multi protocol, but you will have to check that on a per version basis.
