Hello everybody,
i am trying to configure a route reflector and i’ve to come to problem where a network won’t be installed at the ip table because of a wrong next hop.
Here is the part of the topology that i am refering to. R8 is the reflector with R11 the only client. The problem is that R9 and R10 learns from R8 about R15 but with next hop 190.160.118.11 (the same problem occurs with R11), when they sould save R15 and R11 networks from an interface of R8.
I’ve tried using next-hop-self command but as i find out it works only with ebgp connections. Next i tried using route maps but with no success.
Here is the configuration is used:
R8(config)#router bgp 300
R8(config-router)#no synchronization
R8(config-router)#neighbor 190.160.38.3 remote-as 100
R8(config-router)#neighbor 190.160.89.9 remote-as 300
R8(config-router)#neighbor 190.160.108.10 remote-as 300
R8(config-router)#neighbor 190.160.118.11 remote-as 300
R8(config-router)#neighbor 190.160.118.11 route-reflector-client
R8(config-router)#network 8.8.8.8 mask 255.255.255.255
R8(config-router)#exit
R8(config)#access-list 20 permit 15.15.15.15 0.0.0.0
R8(config)#access-list 20 deny any
R8(config)#route-map nxthp permit 10
R8(config-route-map)#match ip address 20
R8(config-route-map)#set ip next-hop 190.160.89.9
R8(config-route-map)#exit
R8(config-router)#neighbor 190.160.89.9 route-map nxthp in
R8(config-route-map)#end
And here is the result show ip bgp command at R9
R9#sh ip bgp
BGP table version is 23, local router ID is 9.9.9.9
r RIB-failure, S Stale
*i15.15.15.15/32 190.160.118 0 100 0 600 i
Can somebody tell me what i am doing wrong or point me at the right direction?
Thank you in advance,
George
