I was following this tutorial https://networklessons.com/uncategorized/cisco-1941w-wireless-configuration-example/ but now I am stuck in the AP interface how do i get back to my router? After following the same tutorial I cannot see the AP ssid i created. Is there anything I making a mistake over:
hostname ap
enable secret 5 $1$1yrR$x9p0kMDk3E.baspobgC7t0
no aaa new-model
ip domain name heritagecoin.com
dot11 syslog
dot11 ssid NWASCO-NET
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 130B0013180F54647A767B
username Cisco password 7 13261E010803
bridge irb
interface Dot11Radio0
description 2.4GHz Radio
no ip address
no ip route-cache
shutdown
encryption mode ciphers aes-ccm
ssid NWASCO-NET
antenna gain 0
station-role root
no cdp enable
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
interface Dot11Radio1
description 5GHz Radio
no ip address
no ip route-cache
shutdown
ssid NWASCO-NET
antenna gain 0
dfs band 3 block
channel dfs
station-role root
no cdp enable
bridge-group 10
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connect ing AP with the host router
no ip address
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface GigabitEthernet0.10
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
interface BVI1
ip address 10.1.1.253 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
bridge 1 route ip
line con 0
no activation-character
line vty 0 4
login local
