Thanks for the ticky article ![]()
So , Copy from Running Config to any destination file , no issue because its overwrite/ replace with running config easily(write command also do the same things). but the issue on copy to running config , its will merge , right ? So if we want to overwrite the running config then the short way is “configure replace”. Please correct me if i am wrong
. Thanks
br//zaman
Hello Mohammad.
Yes, you’ve got it!
