Hi Guys,
So finally got time to play with the setup and currently running in to a issue. The quick problem description will be that I can’t ping the far end tunnel how ever the weird stuff is that there is some sort of connection or communication going on based on these outputs bellow. Also I’m able to ping outside IP of the HUB that is directly facing Internet. It was not working at all first but then I configured another interface on ASA with static NAT and that when ipsec start communicating and also traffic switched form being stuck on udp/500 to udp/4500 which is I believe expected with the NAT
So first this is the topology. Mine setup is the one behind FW the other spoke works just fine.
Tunnel 192.168.221.3 (SPOKE) CSRv -----> ASAv ------> INTERNET -------> CSRv (HUB) Tunnel 192.168.221.1
CSR1000v-R1#sh crypto ipsec sa
interface: Tunnel666
Crypto map tag: Tunnel666-head-0, local addr 10.0.80.2
protected vrf: (none)
local ident (addr/mask/prot/port): (10.0.80.2/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (65.x.x.x/255.255.255.255/47/0)
current_peer 65.x.x.x port 4500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 2556, #pkts encrypt: 2556, #pkts digest: 2556 << --------
#pkts decaps: 816, #pkts decrypt: 816, #pkts verify: 816 << --------------
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 10.0.80.2, remote crypto endpt.: 65.x.x.x
plaintext mtu 1458, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet1
current outbound spi: 0xC891BA8B(3364993675)
PFS (Y/N): N, DH group: none
inbound esp sas:
spi: 0x4FD5738B(1339388811)
transform: esp-3des esp-md5-hmac ,
in use settings ={Transport UDP-Encaps, }
conn id: 2247, flow_id: CSR:247, sibling_flags FFFFFFFF80000008, crypto map: Tunnel666-head-0
sa timing: remaining key lifetime (k/sec): (4607993/611)
IV size: 8 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2248, flow_id: CSR:248, sibling_flags FFFFFFFF80000008, crypto map: Tunnel666-head-0
sa timing: remaining key lifetime (k/sec): (4607987/611)
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
CSR1000v-R1#
CSR1000v-R1#ping 192.168.221.1
Sending 5, 100-byte ICMP Echos to 192.168.221.1, timeout is 2 seconds:
CSR1000v-R1#ping 192.168.221.2
Sending 5, 100-byte ICMP Echos to 192.168.221.2, timeout is 2 seconds:
CSR1000v-R1#sh crypto isa
CSR1000v-R1#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
10.0.80.2 65.x.x.x QM_IDLE 1065 ACTIVE
IPv6 Crypto ISAKMP SA
CSR1000v-R1#sh ip nhrp
192.168.221.1/32 via 192.168.221.1
Tunnel666 created 15:53:05, never expire
Type: static, Flags:
NBMA address: 65.x.x.x
192.168.221.2/32
Tunnel666 created 00:00:46, expire 00:02:18
Type: incomplete, Flags: negative
Cache hits: 6
CSR1000v-R1#
And snip from debug...
Aug 20 17:29:53.534: IPSEC(create_sa): sa created,
(sa) sa_dest= 10.0.80.2, sa_proto= 50,
sa_spi= 0xE8291530(3895006512),
sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 2231
sa_lifetime(k/sec)= (4608000/900),
(identity) local= 10.0.80.2:0, remote= 65.x.x.x:0,
local_proxy= 10.0.80.2/255.255.255.255/47/0,
remote_proxy= 65.x.x.x/255.255.255.255/47/0
(sa) sa_dest= 65.x.x.x, sa_proto= 50,
sa_spi= 0x84FAF211(2231038481),
sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 2232
Aug 20 17:29:53.556: ISAKMP-ERROR: (0):Failed to find peer index node to update peer_info_list
Aug 20 17:29:53.556: ISAKMP: (1061):Received IPSec Install callback... proceeding with the negotiation
Aug 20 17:29:53.556: ISAKMP: (1061):Successfully installed IPSEC SA (SPI:0xE8291530) on Tunnel666
Aug 20 17:29:53.556: ISAKMP-PAK: (1061):sending packet to 65.x.x.x my_port 4500 peer_port 4500 (R) QM_IDLE
Aug 20 17:29:53.556: ISAKMP: (1061):Sending an IKE IPv4 Packet.
Aug 20 17:29:53.556: ISAKMP: (1061):Node 255717431, Input = IKE_MESG_FROM_IPSEC, IPSEC_INSTALL_DONE
Aug 20 17:29:53.556: ISAKMP: (1061):Old State = IKE_QM_IPSEC_INSTALL_AWAIT New State = IKE_QM_R_QM2
Aug 20 17:29:53.782: ISAKMP-PAK: (1061):received packet from 65.x.x.x dport 4500 sport 4500 Global (R) QM_IDLE
Aug 20 17:29:53.782: ISAKMP: (1061):deleting node 255717431 error FALSE reason "QM done (await)"
Aug 20 17:29:53.782: ISAKMP: (1061):Node 255717431, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
Aug 20 17:29:53.783: ISAKMP: (1061):Old State = IKE_QM_R_QM2 New State = IKE_QM_PHASE2_COMPLETE
Aug 20 17:29:53.783: IPSEC(key_engine): got a queue event with 1 KMI message(s)
Aug 20 17:29:53.783: IPSEC(key_engine_enable_outbound): rec'd enable notify from ISAKMP
Aug 20 17:29:53.783: IPSEC(update_current_outbound_sa): updated peer 65.x.x.x current outbound sa to SPI 84FAF211
Aug 20 17:30:13.782: ISAKMP: (0):Sending an IKE IPv4 Packet.
Aug 20 17:30:33.783: ISAKMP: (0):Sending an IKE IPv4 Packet.
Aug 20 17:30:40.951: %DUAL-5-NBRCHANGE: EIGRP-IPv4 200: Neighbor 192.168.221.1 (Tunnel666) is down: retry limit exceeded
Aug 20 17:30:42.944: %DUAL-5-NBRCHANGE: EIGRP-IPv4 200: Neighbor 192.168.221.1 (Tunnel666) is up: new adjacency
Aug 20 17:30:43.782: ISAKMP: (1061):purging node 255717431
Aug 20 17:30:53.783: ISAKMP: (0):Sending an IKE IPv4 Packet.
Aug 20 17:30:53.866: ISAKMP-PAK: (1061):received packet from 65.x.x.x dport 4500 sport 4500 Global (R) QM_IDLE
Aug 20 17:30:53.866: ISAKMP: (1061):set new node 3640371719 to QM_IDLE
Aug 20 17:30:53.867: ISAKMP: (1061):processing HASH payload. message ID = 3640371719
Aug 20 17:30:53.867: ISAKMP: (1061):processing DELETE payload. message ID = 3640371719
Aug 20 17:30:53.867: ISAKMP: (1061):peer does not do paranoid keepalives.
Aug 20 17:30:53.867: ISAKMP: (1061):Enqueued KEY_MGR_DELETE_SAS for IPSEC SA (SPI:0x6626A8AB)
Aug 20 17:30:53.867: ISAKMP: (1061):deleting node 3640371719 error FALSE reason "Informational (in) state 1"
Aug 20 17:30:53.867: IPSEC(key_engine): got a queue event with 1 KMI message(s)
Aug 20 17:30:53.867: IDB is NULL : in crypto_ipsec_key_engine_delete_sas (), 5732
Aug 20 17:30:53.867: IPSEC(key_engine_delete_sas): rec'd delete notify from ISAKMP
Aug 20 17:30:53.867: IPSEC: still in use sa: 0x7F73F3856A50
Aug 20 17:30:53.867: IPSEC(key_engine_delete_sas): delete SA with spi 0x6626A8AB proto 50 for 65.x.x.x
Aug 20 17:30:53.867: IPSEC(delete_sa): deleting SA,
sa_spi= 0x3865CF33(946196275),
sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 2229
sa_spi= 0x6626A8AB(1713809579),
sa_trans= esp-3des esp-md5-hmac , sa_conn_id= 2230
Aug 20 17:30:53.868: IPSEC(send_delete_notify_kmi): not sending KEY_ENGINE_DELETE_SAS
Aug 20 17:30:53.872: IPSEC(ident_delete_notify_kmi): Failed to send KEY_ENG_DELETE_SAS
Aug 20 17:30:53.872: IPSEC(ident_update_final_flow_stats): Collect Final Stats and update MIB
IPSEC get IKMP peer index from peer 0x7F73F3854610 ikmp handle 0x80000006
IPSEC IKMP peer index 0
[ident_update_final_flow_stats] : Flow delete complete event received for flow id 0x240000E5,peer index 0
Aug 20 17:31:13.866: ISAKMP: (0):Sending an IKE IPv4 Packet.
Aug 20 17:31:33.867: ISAKMP: (0):Sending an IKE IPv4 Packet.
Aug 20 17:31:43.867: ISAKMP: (1061):purging node 3640371719
Aug 20 17:31:53.868: ISAKMP: (0):Sending an IKE IPv4 Packet.
Aug 20 17:32:02.453: %DUAL-5-NBRCHANGE: EIGRP-IPv4 200: Neighbor 192.168.221.1 (Tunnel666) is down: retry limit exceeded << ------
Aug 20 17:32:06.366: %DUAL-5-NBRCHANGE: EIGRP-IPv4 200: Neighbor 192.168.221.1 (Tunnel666) is up: new adjacency << ---------
