I need to check BGP links and would like to have this done within 180 sec after
event syslog pattern %BGP-5-ADJCHANGE:*
how can I increase the run time to 190 sec, adding another event:
event config maxrun 200
will exclude the first one that detect the change
Is it possible to change the policy so I can have a script running for 190 sec?
if yes how?
event syslog pattern "%BGP-5-ADJCHANGE:*"
action 1.0 cli command "enable"
action 1.1 cli command "sh bgp sum"
action 1.2 regexp "Active" "$_cli_result"
action 1.3 if $_regexp_result eq 1
action 1.3.1 syslog priority alerts msg "Message Sent"
action 1.5 regexp "Idle" "$_cli_result"
action 1.6 elif $_regexp_result eq 1
action 1.6.1 syslog priority alerts msg "Message Sent"
action 1.7 end
