I have this simple EVPN VPWS Multihoming setup:
The great part about this is that many of the routes that you see in traditional LAN multihoming such as T2, T1 per ES or T4 are irrelevant/ignored in this scenario.
My question is. If you take R1-XR as an example, it will receive routes from R4-XR and R5-XR and notice that the ES matches for both of them. R1-XR now knows that they connect to the same ethernet segment - 45.x.x.x.
R1-XR can now load-balance traffic when sending it towards the other end of the VPWS. This is the confusing part for me:
R1-XR will load-balance to both R4-XR and R5-XR, yet the entry above is a little confusing.
Why did it generate a local label of 24010? Also, doesn’t the MPLS entry above state "if a packet is received with an MPLS label of 24010, it’s swapped with 24008 (since R4 and R5 both generated the same label value) and sent over EVI 100?
I don’t understand why did it generate a local label of 24010. When SW1 even generates any kind of traffic, it won’t label it with 24010 at all, so how does ECMP work with a multhomed VPWS?
