Front-Door VRF (FVRF)
I came across this cool topic of Front-Door VRF (FVRF).
Front Door VRF is to isolate the underlay and overlay networks, both to avoid potential routing recursion issues as well as to add a layer of security by segmenting the underlay and overlay at L3.
Can I suggest to create a lesson on that?
Pascal
Hello Pascal
Thanks for the suggestion! You can officially make your suggestion at the following member ideas page:
There you can suggest new topics, and you may find that others have made similar suggestions, and you can add your voice to theirs.
The specific topic is very interesting, and is associated with VRF-Aware IPsec. The truth is I haven’t found very much Cisco documentation about it, so it would make a good addition. Here is a link to Cisco documentation that mentioned it briefly…
Hi Pascal
I stumbled across the same topic a while ago - Denise Fishbourne has a cool blog on the topic including topologi and config examples.
Its quite easy to replicate her setup based on the blogpost.
Have fun
Orla
