I have ASA firewalls with multiple VLANs trunked on their interfaces, with sub-interfaces for each vlan. As discussed in a previous post, I use the sub-interface’s IP as the default gateway for the corresponding VLAN.
However, these ASAs are in HA mode (active/standby) and therefore my configuration looks like:
ip address IP1 MASK standby IP2
I haven’t tested live but I wonder what will happen when failover occurs - the secondary ASA will become active, but what IP will be the “master”? IP1 or IP2?
In case IP2 becomes the master, then I simply loose my VLAN’s default gateway, am I correct?
