I’m not sure of the respond to this question. Help to clarify why this answer is correct please.
Hello Ayong
The correct answer is indeed:
“The default VLAN should always be deleted and never used”
Note that the question is asking which statement is false. The default VLAN cannot be deleted, and therefore the statement is false. All the other options are true.
LOL, I misunderstood the question. Thank you so much.
