I’m using the following topology and I have configured a static route on R3 and R4 for 5.5.5.5/32, but on R4 with AD 250. Between R3 and R4 the iBGP session is up and I can see that I’m advertising the prefix 5.5.5.5/32. Why does R4 choose that static route with AD 250, instead of the iBGP route with AD 200?
Thanks a lot.
R3#show ip bgp neighbors 10.0.0.4 advertised-routes
BGP table version is 12, local router ID is 192.168.0.3
*> 5.5.5.5/32 10.0.0.10 0 32768 i
*> 10.0.0.0/24 0.0.0.0 0 32768 i
Total number of prefixes 2
R3#show ip bgp 5.5.5.5
BGP routing table entry for 5.5.5.5/32, version 12
Paths: (2 available, best #1, table default)
Advertised to update-groups:
8 11
Refresh Epoch 1
Local
10.0.0.10 from 0.0.0.0 (192.168.0.3)
Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
Refresh Epoch 1
Local
10.0.0.10 from 10.0.0.4 (192.168.0.4)
Origin IGP, metric 0, localpref 100, valid, internal
R3#show ip route 5.5.5.5
Routing entry for 5.5.5.5/32
Known via "static", distance 1, metric 0
Advertised by bgp 100
Routing Descriptor Blocks:
* 10.0.0.10
Route metric is 0, traffic share count is 1
R4#show ip bgp 5.5.5.5
BGP routing table entry for 5.5.5.5/32, version 6
14 15
Refresh Epoch 1
Local
10.0.0.10 from 10.0.0.3 (192.168.0.3)
Refresh Epoch 1
Local
10.0.0.10 from 0.0.0.0 (192.168.0.4)
R4#show ip route 5.5.5.5
Known via "static", distance 250, metric 0
* 10.0.0.10
