How to configure ACLs for multicast across ASA5516
I’m troubleshooting a multicast-related issue across an ASA 5516, and finding it hard to understand how the ACL to permit multicast traffic across its interfaces works. The logical topology below shows my setup.
The monitoring server in far left needs to view multicast video stream from cameras (Cam 2 & Cam 4) in far right. The L3 switches route between vlans (different subnets) and the monitoring server is able to receive unicast streams (via the ASA) from the cameras.
The ASA interfaces shown are at the same security level (100). Multicast routing is configured and PIM sparse mode RP is configured as one of the L3 switches. Interface configs:
interface GigabitEthernet1/2
 description Inside Interface
 nameif inside
 security-level 100
 ip address 10.23.140.5 255.255.255.0
 igmp join-group 224.16.17.15
 igmp join-group 224.16.17.8
 ospf message-digest-key 1 md5 *****
 ospf authentication message-digest
interface GigabitEthernet1/3
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/3.200
 description Cnxn to Monitoring Network
 vlan 200
 nameif GENETECFED
 security-level 100
 ip address 192.168.200.17 255.255.255.0
 ipv6 address fd87:777d:126a:ce5b::200:17/64
 ipv6 enable
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
pim rp-address 10.23.201.1 EVL-GENETEC-MCAST-GRPS
When I test using packet tracer, with source as multicast group IP and destination as monitoring server, the output shows the packet is dropped due to a configured ACL. There is an ACL on the ASA interface (10.23.140.5) and I have added entries to permit the multicast traffic but I don’t seem to be getting it right. The ACL is shown below
 access-list inside_access_in extended permit tcp object-group Systems_Networks any object-group EXTERNAL_WEB_ACCESS
access-list inside_access_in extended permit udp object-group DNS_SERVERS_LOCAL object-group DNS_SERVERS_EXTERNAL eq domain
access-list inside_access_in extended permit udp object-group Systems_Networks object-group DNS_SERVERS_EXTERNAL eq domain
access-list inside_access_in extended permit udp object-group VOIP-GW-CUBE object-group SIP_REGISTRARS_EXTERNAL eq sip
access-list inside_access_in extended permit tcp object-group VOIP-GW-CUBE object-group SIP_REGISTRARS_EXTERNAL eq sip
access-list inside_access_in extended permit icmp any any echo-reply
access-list inside_access_in extended permit igmp any any
access-list inside_access_in extended permit pim any any
access-list inside_access_in extended permit tcp object-group CCTV-SUBNETS object EXT_GENETEC_SRV_HOST192
access-list inside_access_in extended permit udp object-group CCTV-SUBNETS object EXT_GENETEC_SRV_HOST192
access-list inside_access_in extended permit ip object-group EVL-CCTV-MCAST-GRPS any
access-list inside_access_in extended permit ip any object-group EVL-CCTV-MCAST-GRPS
access-group inside_access_in in interface inside
object network EXT_GENETEC_SRV_HOST192
 host 192.168.50.42
 description Genetec SC Server
object network EXT_GENETEC_SRV_SUBNET192
 subnet 192.168.50.0 255.255.255.0
object network EXT_GENETEC_SRV_SUBNET172
 subnet 172.16.50.0 255.255.255.0
object-group network CCTV-SUBNETS
 network-object 10.23.40.0 255.255.255.0
 network-object 10.23.41.0 255.255.255.0
object-group network EVL-CCTV-MCAST-GRPS
 network-object 224.0.0.0 240.0.0.0
object-group network ETS-MCAST-RECIPIENTS
 network-object object EXT_GENETEC_SRV_SUBNET192
 network-object object EXT_GENETEC_SRV_SUBNET172
Any advice on tackling this would be appreciated.
Hi Toritsejo,
I wasn’t sure how the ASA would work with multicast and two interfaces on the same security-level so I just labbed this up. Here’s the VIRL file (rename the TXT extension to virl):
asa_multicast_virl.txt (8.5 KB)
Here are the configs:
hostname ASA1
multicast-routing
interface GigabitEthernet0/0
 nameif INSIDE
 security-level 100
 ip address 192.168.100.254 255.255.255.0
interface GigabitEthernet0/1
 nameif OUTSIDE
 security-level 100
 ip address 192.168.200.254 255.255.255.0
pim rp-address 192.168.100.1
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
 class inspection_default
  inspect ip-options
  inspect netbios
  inspect rtsp
  inspect sunrpc
  inspect tftp
  inspect xdmcp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect esmtp
  inspect sqlnet
  inspect sip
  inspect skinny
  inspect icmp
service-policy global_policy global
hostname H1
no ip routing
no ip cef
 ip address 192.168.1.101 255.255.255.0
 ip igmp join-group 239.2.2.2
hostname R1
ip multicast-routing
ip cef
 ip pim sparse-mode
interface GigabitEthernet0/2
 ip address 192.168.100.1 255.255.255.0
 ip pim sparse-mode
ip http server
ip pim rp-address 192.168.100.1
ip route 0.0.0.0 0.0.0.0 192.168.100.254
hostname R2
ip cef
 ip pim sparse-mode
 ip address 192.168.200.2 255.255.255.0
 ip pim sparse-mode
ip http server
ip route 0.0.0.0 0.0.0.0 192.168.200.254
hostname H2
no ip routing
no ip cef
 ip address 192.168.2.102 255.255.255.0
 ip igmp join-group 239.1.1.1
ip default-gateway 192.168.2.254
I can get multicast traffic in both directions without issues between H1 and H2. I’m not sure if packet-tracer works well for multicast traffic. When I try it, I’m also getting a deny message. Is your ASA really dropping it? Nothing in the mroute table?
ASA1# show mroute 239.1.1.1
Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group,
       C - Connected, L - Local, I - Received Source Specific Host Report,
       P - Pruned, R - RP-bit set, F - Register flag, T - SPT-bit set,
       J - Join SPT
Timers: Uptime/Expires
Interface state: Interface, State
(*, 239.1.1.1), 01:02:05/00:03:25, RP 192.168.100.1, flags: S
  Incoming interface: INSIDE
  RPF nbr: 192.168.100.1
  Immediate Outgoing interface list:
    OUTSIDE, Forward, 01:02:05/00:03:25
(192.168.1.101, 239.1.1.1), 00:01:57/00:03:10, flags: ST
    OUTSIDE, Forward, 00:01:57/00:02:31
Can we have some Lessons on Other Networking Vendors Devices ,
Meaning , can we have some lessons on Juniper and Palo Alto pls ???
Hello Cisco-admin
For the time being, the NetworkLessons site is devoted to preparing networking professionals for CCNA, CCNP and related Cisco certifications. For the foreseeable future at least, no additional vendors will be added. However, if you would like your request to be recorded, go to the following link and post your lesson idea. If enough people want the same thing, maybe it may be done in the future!
